Brake pads for Willow Springs - Page 2 - SR20 Forum
Go Back   SR20 Forum > What's New > Convention Archive > 2004 SE-R National Convention (Southern California)
Old 05-05-2004, 08:50 PM   #21 (permalink)
Road Race Addict
Re: Brake pads for Willow Springs
Yeah I got some Bobcats and man they grip when they are cold!!! They dust like crazy but its a very light dust non of that corrosive crap. I orginally was shellshocked by the price but after having them on the car for a few months now they are worth every penny.
www.LPTuning.com (Coming soon)
LP Tuning is offline
Old 05-05-2004, 10:39 PM   #22 (permalink)
employment whiplash, NC
You want dust, try some Axxis Ultimates
Edit: Oh, and thanks for the kind words on the pads
Matt
MaddMatt is offline
Old 05-05-2004, 10:43 PM   #23 (permalink)
Anti-Search Nazi
Is the price for front and rears? I didn't see anything about that.
Steve Williams
The Replacement, Replacement Radmobile
SR20steve is offline
Old 05-06-2004, 07:52 AM   #24 (permalink)
Price is for fronts only.
MaddMatt is offline
Old 05-17-2004, 08:25 PM   #25 (permalink)
Everyone get their shizzle???
MaddMatt is offline
Old 05-17-2004, 09:01 PM   #26 (permalink)
No soup for you
Feedback Score: 30 reviews
Mine arrived a few days ago. Getting ready to go install them, actually. Thanks!
John
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Big John is offline
Old 05-18-2004, 02:06 AM   #27 (permalink)
No soup for you
It seems as though the pad is to big to be installed w/ the shims. Is this normal? I figure worst case they'll squeal a bit, then when they wear some I can re-install the shims. What do you think?
John
Big John is offline
Old 05-18-2004, 07:56 AM   #28 (permalink)
Power to spare...
Feedback Score: 13 reviews
John
Mwuhahaha! Panther pads? They squeal so bad that when you're just cruising they make a sound as the pads are barely rubbing the rotors. With the windows up its not that bad, but roll them down and every stop sign/light you come to you won't BELIEVE how loud they are! I bought some shims at Pep boys and even used a little Permatex disc quiet. It helped.
John did you use a clamp to push in the caliper piston? I had to. Make sure if you have to do this you monitor your master cylinder for spill over as you squeeze them in.
The squealing issue is a personal tolerance thing though. It may not bother you at all. Turn up the radio!
'97 200SX SE-R GT28RS Powered
'06 Mitsubishi Lancer Evolution IX
'09 BMW 335i E90
Thomas Reynolds is offline
Old 05-18-2004, 10:11 AM   #29 (permalink)
No soup for you
Oh, goody! I still have a good set of metalmasters I can swap back in if they get to intolerable. I tried using a clamp, that sucker is as far as it will go. Once they get a bit of wear, I'll put the shims on 'em w/ some of that stop squeal stuff. Thanks for the heads up.
John
Big John is offline
Old 05-18-2004, 10:31 AM   #30 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
I finally swapped my Ultimates back in for my Panther +s. It like I went back to stock brakes. Ultimates suck compared to Carbotechs. The panthers are a bit loud, and dusty, but its worth it for the better pads. I'll be buying either these or the XPs next time.
eric96ser is offline
Old 05-18-2004, 10:42 PM   #31 (permalink)
Do not reuse the shims. We make track pads extra thick with more material. More material = longer wear.
MaddMatt is offline
Old 05-20-2004, 02:40 AM   #32 (permalink)
70/30 Racing
Rockwood's Avatar
mine only squeal when its below 60* on the first few stops
after that, theyre pretty silent (well, i cant hear them over the 3" exhaust)
MotoIQ Project G20:
Rockwood is offline
Old 05-25-2004, 05:49 AM   #33 (permalink)
No soup for you
I agree. After the convention weekend, I have to say even the first stop I made before bedding them in, these pads were leaps and bounds better than the metal masters. Hardly any squeaking. Great brakes pads. I'm sold.
John
Big John is offline
