MY Deeply Sad Convention Report... Part 1 - Page 3 - SR20 Forum
Go Back   SR20 Forum > What's New > Convention Archive > 2005 SE-R National Convention (Austin, TX)
Old 04-13-2005, 01:44 AM   #41 (permalink)
Hostile Aberration
Shawn B's Avatar
Feedback Score: 10 reviews
Erich, please check the PM sent to you and Rockwood .
Originally Posted by Shawn B....muttering to himself
Ah...the "edit" button at work. Might as well tidy up at bit while I'm here.
Muy Bueno!
SORRY to those that are completely confused by this stange, rambling, OT dialog. Poo happens. Erich and I are buds now, situation resolved, I apologize profusely for the interuption. (Shawn slips out the back very quietly...). LOL.
Back to Erichs car.....I hope you get it back quick, and glad the engine didn't sieze.
Shawn B is offline
Old 04-13-2005, 01:50 AM   #42 (permalink)
Been sold out!!
Feedback Score: 31 reviews
Well dammit... You beat me... I edited it before you posted and you still managed to reply to it... Uhg... No man, check YOUR pm...
Yeah... You better believe I'm glad the damn thing didnt seize either... I'd be taking P@'s offer on that footstool if that happened...
Cheers-
Erich
Erich
Wicked R is offline
Old 04-13-2005, 03:05 AM   #43 (permalink)
I talked to Clark Steppler today about this oil pump situation... He feels that the pump is fine for the DE or DET motor.. He said that he has some DE (non turbo) guys that run them in thier road race cars.. because the pickup tube and inlet of the pump is engineered to keep the pump from cavitating at high RPM.. which is apparently a problem on the DE/DET pumps. He said that the oil pressure isn't an issue.
We summed it up as a faulty part.. The bolt was probably improperly TQ'd at the factory, or the metal fatigued.. I will be inspecting all of my oil pumps.. new and used, from now on. I guess it wouldn't hurt to put a dab of Loctite on the bolt while I'm in there.
Travis
Travis Burelle / Forced Induction Racing
VQ swaps, Engine builds, Turbo kits, Chassis work..
985-713-1542 (www.fi-r.net)
unlucky is offline
Old 04-13-2005, 04:22 AM   #44 (permalink)
Feedback Score: 47 reviews
I still want to know what exactly failed on this.
Yahnozha is offline
Old 04-13-2005, 09:32 AM   #45 (permalink)
70/30 Racing
Rockwood's Avatar
Originally Posted by Big John
I see where you're going, considering constant volume. However the sustained volume at 5000 rpm from the pump is different from the sustained volume at 7000 rpm. If you ramp up from 5000 rpm to 7000 rpm at WOT, the volume pumped can *back up* through a restrcition and increase pressure. Were as a slow constant through rpm range will eventually result in the same volume and pressure it is not imediate. I don't think it's a valid argument to say that casual driving will result in the same Peak pressures as hard driving. I don't think most people will keep their car suspended at higher RPMs without WOT.
EDIT:
I'm viewing it from function over time perspective. Does it make any sense?
no, the oil pump's pressure curve should be a relatively linear RPM vs pressure curve. just becuase it is accelerating rapidly, does not mean it is going to "back up". the oil loss through bearings, VVL, cam squirters, etc, is always the same (or close enough) regardless of RPM. whether you're flooring it or not, the oil pump is always making the same pressure because it is driven off the crank. think of a supercharger.
MotoIQ Project G20:
Rockwood is offline
