I would change it when you get home. My oil in my VE will have 3 track days on it, but less than 1500 miles when I get home from the Convention; so I'll probably change it then. I used German Castrol this time, so I'll do another oil analysis also.
I wouldn't hassle with an oil change the day of the track day unless something major required it.
I would do it after the event. Shouldn't be contaminated for quite some time, but just in case you overheat the oil (extremely likely with SR20s that don't have oil coolers), I would change it after the track event.
