i had an NX2000 and a trashcan jumped out in front of me and now i'm tryin to get a 96 200sx se-r and i was wonderin if anything from the b-13 would fit on a b-14..... i'm considering parting out my NX but wanna know if i can use anything... u know????
peace out
Originally Posted by brooklyn nx
1: Dont give up 2: You need to get a job that pays a little better 3:Get a girlirfriend who supports your cause. I got 2 cars that need help and no steady work but that dont stop me from getting a little done at a time,If you love your car and love what you do youl get through it.
If you were to use 200sx pads in an NX2000 the pads could fall out from clearance issues.
Umm... I don't know if there's something f*cked up about how Nissan brakes work, but every single car I've worked on has the caliper piston move inwards to keep constant pressure on the pads and keep the rotors sandwiched. The pads are NOT going to fall out, no matter how thin the rotor gets, unless the caliper pistons have reached their maximum extension. That's why one of the prime things you have to do when replacing pads is to press or turn the piston back into the caliper - they expand to spec when you first step on the brakes.
__________________ 1988 CRX Si
11.84 @ 118 mph STOCK BLOCK. Don't laugh 'cause it's FWD unless you can bring it.
I beg to differ. Serban's Nx2000 had a SE-R Rotor in it and his brake pad fell out. That's where I got the picture
yeh, i found a 98 200sx, came up for $1000, i dont thyink the guy knew what he had, anyways, he thinks hois transmition is shot, its an automatic and we wanna get it home before we assess the problem and fix it, but i plan to do a manual swap anyways... hehehe. i came up.
