Old 12-27-2005, 06:16 PM   #1 (permalink)
possible problem
hey guys any input on this issue would be appreciated so here it is. i have a b14sr with 66k and when the engine's rpms are declining to idle i am getting a rattle from the area around the passenger area of the engine bay(which i think is the 4th cylinder). i think i know what it is but i would like to know what you guys think but it doesnt sound like anything simple.
md200sxser is offline   Reply With Quote
Old 12-28-2005, 12:10 AM   #2 (permalink)
The SE-R Sitter
What is your timing set to? Do a compression test while your at it. Because it sounds like it's coming form the engine it can be coming from somewhere else from under the hood.
Good luck.
http://www.s r 2 0-f o r u m.com/
For those looking for a new home.
SE R Madness is offline   Reply With Quote
Old 12-28-2005, 01:06 AM   #3 (permalink)
Spool...
Just my two cents... I have prothanes. and i have rattle noises coming from everywhere. Ivce just gotten used to it. I would have a friend (underneath hood) semi-revving the engine with you inside the car. and just listen and pinpoint where exactly the noise is.as far as it being and engine problem or internal car problem. The limits
"Uncertainty declines when people reduce operations to routines"
Reality sucks is offline   Reply With Quote
Old 12-28-2005, 01:42 AM   #4 (permalink)
well my timing is stock or it should be but im gonna take of the valve cover to check out the chain.
Old 12-28-2005, 03:38 AM   #5 (permalink)
They're just cones!
The chain will be fine, there's a tensioner built into the system, and I've never heard of an sr have a chain problem. If it's actually in the motor, odds are it's a rod bearing. 66k is way early for that though. I bet it's something loose in the engine bay. I had a loose corner marker once that rattled like hell, took me about a week to find it.
Matt
Boosted as of 11/15/05
Driven97 is offline   Reply With Quote
Old 12-28-2005, 11:15 AM   #6 (permalink)
Phillies Are 08 Champs
Trader Rating: 41 (100%)
Or it could be the plastic fender liner, if it gets loose at the bottom of the front bumper cover it'll rub like crazy. That's what happen to me and I thought it was an internal engine noise.
JET
96 QM1 SE-R
98 AL0 SENTRA GLE VE
92 AH3 SE-R ***SOLD 5/25/08***
GO PHILLIES!!!!!
2008 WORLD SERIES CHAMPIONS
sr20jet is offline   Reply With Quote
Old 12-28-2005, 01:00 PM   #7 (permalink)
working on it
swiss's Avatar
Trader Rating: 23 (100%)
http://www.sr20forum.com/showthread....+chain+guid e
Old 12-28-2005, 04:03 PM   #8 (permalink)
thank you swiss i think that is what it is because the rattling doesnt start until the engine is warm.so ill be checking that out but i believe that is what it is
Old 12-28-2005, 06:13 PM   #9 (permalink)
working on it
swiss's Avatar
No sweat.
Old 01-06-2006, 02:46 PM   #10 (permalink)
some more issues
alright, i had removed the safety guide from the top, and i had accidently dropped one of the bolts in the timing area i could not find it, so i fired her up and everything was fine. after going down the road initially everything is good and all of a sudden the my intake sounded a ton louder and every gear it stuggles to rev higher then 5k. have replaced the egr but still get the code(probaly the pipe) could that be the problem because at higher idle it sounds like the engine is missing any insight would glady be appreciated.
