Old 01-19-2006, 10:34 PM   #1 (permalink)
SE-R instrument panel to SX SE
I searched for this and didn't find it so hopefully it wasn't a poor search string on my part.
Can you use a SE-R instrument panel in your SE? Even better...and yes I know this is rice, rice baby...could I keep the 200sx se instrument panel and put SE-R replacement reverse glow gauges in it? *Ducks in anticipation of wrenches being thrown due to rice nature of the question*
GG
gringogrande is offline   Reply With Quote
Old 01-19-2006, 10:48 PM   #2 (permalink)
should be no problem to put se-r reverse glows in them. are they aftermarket reverses?
As long as the cable that connects to the instrument panel is the same size then no problem there either. Except it almost worthless because only diff. really is the guages in which you'd just want to get some overlays that wrap right around the needle and no need to take the needle off. This is if you are going with aftermarket guages often found by ricers on ebay.
SarCaZm is offline   Reply With Quote
