Old 07-17-2007, 10:16 PM   #1 (permalink)
200 whp club
? and don't understand
Ok got a stock DET in my B14. Whenever i am under boost and i change gears and push the gas...... it is like dead no boost. i have slow down a bit the the boost will kick in. It is almost like it hits a brick wall. Any one run into a problem like this
g20 Ecu
Safc2
Damien
B15 SE
B13 SE-R
dmp316 is offline   Reply With Quote
Old 07-17-2007, 10:20 PM   #2 (permalink)
[sr20]sean
dcr1d3r13's Avatar
det isnt stock in a ser
96 200sx se-r
myspace
dcr1d3r13 is offline   Reply With Quote
Old 07-17-2007, 10:34 PM   #3 (permalink)
200 whp club
omg i know DET swap..........
Old 07-17-2007, 10:39 PM   #4 (permalink)
[sr20]sean
dcr1d3r13's Avatar
ohh ok check the vacuum lines or the wastegate spring maybe theres no vacuum or the spring isnt the right one for the psi ur running
Old 07-17-2007, 10:42 PM   #5 (permalink)
shift_boost
^^^ Has no idea what he is talking about. The car has lag?
myspace
95 chevy dually big, black, low, and diesel
twisted200ser is offline   Reply With Quote
Old 07-18-2007, 12:02 AM   #6 (permalink)
Wiggle wagon driver...
Trader Rating: 26 (100%)
is the blow off valve recirculating back into the intake pipe, or is it just blowing off into the atmosphere
200sx w/JDM highport swap..turbo build in the works
05 Altima
01 F150
Originally Posted by KdubL View Post
she looks funky...like she just finished eating a doo doo samich
Katana200sx is offline   Reply With Quote
Old 07-18-2007, 11:43 AM   #7 (permalink)
200 whp club
atmosphere
Old 07-18-2007, 12:21 PM   #8 (permalink)
shift_boost
The problem lies there then. Not a blow through setup? If it is not the bov is letting out metered air causing the car to run really rich between shifts. Making the car kinda bog until it can recover. Make it a blow through or recirc the bov.
Old 07-18-2007, 01:31 PM   #9 (permalink)
No soup for you
Trader Rating: 30 (100%)
To make sure it is indeed the bov and not a tuning issue, you can tighten the BOV (if it's adjustable) and set the decel air function on the AFC per the manual. If the throttle response gets better, recirc or blow through as recommended above. If it doesn't change, check the plugs and consult a wideband ASAP.
B12 turbo madness
424 whp / 328 ft. lbs
2440 lbs. w/ a full tank
B14 VE Hotness
244 whp / 228 ft. lbs
Old 07-19-2007, 10:16 PM   #10 (permalink)
200 whp club
found out that is could be a big vac leak................... going to check this out
Old 07-19-2007, 10:25 PM   #11 (permalink)
Mr.200SX @ the dash
Trader Rating: 31 (100%)
Boost leak test is your bestfriend!
"IF YOU AINT 1ST YOU'RE LAST"
JGsnismoser is offline   Reply With Quote
