Old 11-19-2000, 01:19 PM   #1 (permalink)
dorina, yea, yea
I would really really like to see a picture of your dyno plot. Can you post it anywhere??
I had the same mods except stock ECU and stock exhaust (and PRCAI with K&N) and I got 140whp. Swapping just an aftermarket muffler gained 5whp. I would expect you to be closer to 150 peak whp. What wheels/tires did you have?
http://members.home.com/noslo200/jason%20muffler%20swap.jpg
Old 11-19-2000, 01:35 PM   #2 (permalink)
huh?
Teal97 is offline   Reply With Quote
Old 11-19-2000, 01:48 PM   #3 (permalink)
huh?
Old 11-19-2000, 06:26 PM   #4 (permalink)
huh?
Old 11-20-2000, 12:41 AM   #5 (permalink)
dyno results
huh?
Old 11-20-2000, 10:57 AM   #6 (permalink)
dorina, yea, yea
When did you buy your UR pulleys?
There were some early on with timing marked incorrectly, I think. Anybody know more about this??
Old 11-21-2000, 11:11 AM   #7 (permalink)
I have the 4 pulley set and my crank pulley timing marks are a bit off. I set the timing on the stock pulley and had it confirmed on a consult. The i installed the UR 4 pulley set and my 15 degree timing mark is a bit too far to the right. I know the timing was at 15 but the UR pulley reads about 14. For what its worth.
gpser96 is offline   Reply With Quote
Old 11-21-2000, 11:33 AM   #8 (permalink)
dorina, yea, yea
I dont think the consult can actually give a good timing number.
But if you had the timing at 15 with the stock pulley, then put the UR pulley in (and never touched the distributor), and the timing read 14 on the UR pulley, you should be fine.
Old 11-22-2000, 12:31 AM   #9 (permalink)
Runs like its fine..
Old 11-22-2000, 04:18 AM   #10 (permalink)
huh?
Old 11-22-2000, 11:36 AM   #11 (permalink)
SlowSeR and i are headed to a dyno on tuesday. I am going to fiddle with timing anf get a base line at 15 degrees and move it to around 17 or so. I have the wolf computer so i should be at 15 but i am curious as to any HP boost. I'll post results from both ourt cars, his is a '93 and mine 96, with identical preps.
Old 11-22-2000, 04:51 PM   #12 (permalink)
huh?
Old 10-20-2002, 05:02 AM   #13 (permalink)
new dyno #'s
huh?
Old 10-20-2002, 11:00 AM   #14 (permalink)
Re: new dyno #'s
Originally posted by Teal97
154.7 peak hp/139.9peak torque
150.5/136 (sae corrected)
So when are you bringing it out to SIR?
Dan_93SER is offline   Reply With Quote
Old 10-20-2002, 06:38 PM   #15 (permalink)
huh?
