I did my girls last week. If the car was here I'd take pictures.
I got the 7pc set from ebay for $23.
- remove dash (2) phillips screws on the top of cluster(guage bezel)
- remove (4) philipps screws releasing cluster from dash
- remove plastic cover over cluster(be careful, I let the woman contribute and she cracked it)
- speedo, tach are both held on by (2) small philipps screws
- secure (2)^^above^^white faced guages with the philipps screws
- the other 5 can be removed with delicacy
- replace other 5 with the white replacements
- attach (4)connectors to the main guage power supply
- Run power supply behind dash to the right so it will hang behind the centre console
- insert (4) philipps screws to secure cluster to dash
- insert (2) philipps screws to secure gauge bezel
- remove cap hiding (1) philipps screw, remove screw in console(between hazard and rear defrost buttons)
- pop out centre console with flat head screw driver
- remove deck (4) philipps screws
- locate indiglo guage power supply
- splice power of indiglo (+) to (+)illumination on cd player
- splice ground of indiglo (-) to (-)illumination on cd player
- mount your [< >] remote for illumination power supply control
- mount cd player, insert (4) philipps screws
- install centre console
- install (1) philipps screw, screw cap
You are good to go!
2002 G20 Sport
1999 G20t
1997 Mitsubishi Eclipse Spyder
1993 318i
