Old 06-03-2003, 04:47 PM   #1 (permalink)
Odd Noise
I'm guessing I have a spring that's going bad, but I'm curious of other people's opinions before I go out buying expensive stuff to find out I was wrong. My front left corner creaks when the suspension travels a bit like going over a pothole at normal cruising speeds, or even if I go into a right curve and pull the wheel in to the right a bit, it almost sounds like metal stressing but it doesn't do it when I bounce that corner by pushing on it or if I jack that corner up. Consequently that is also the same side with a positive 1.2 caster (not sure how as I've never hit a curb and it was fine before this last New Years, personally I blame the Louisiana State roads when I drove to Texas for Christmas, they killed my struts as well). I'm also using stock springs with KYB GR2's in front and back if this helps. Any suggestions would be greatly appreciated.
97pocketrocket is offline   Reply With Quote
Old 06-03-2003, 04:54 PM   #2 (permalink)
Air filter cleaner masta
MarkSR20's Avatar
Trader Rating: 28 (100%)
First thing, do you have a CAI or any pipes going through your fender?? Check to see if they are rubbing on metal.
97 smurf
94 silvia vert (For Sale)
98 Dodge Ram (For Sale)
http://www.sr20convention.com
MarkSR20 is offline   Reply With Quote
Old 06-03-2003, 05:35 PM   #3 (permalink)
Ahh, that's a good point. I do have a cai going through it, I'll check it, thanks.
