Originally Posted by maxximtl
The stock wattage is 55 watt for the foglight bulbs. They do make 35 watt H3 bulbs, but that is not what is spec'd for the B14. Do not exceed 55 watts though, the 100 watt bulbs will melt the wiring harness.
The beam pattern on the stock foglights isn't very good. No bulb will get them to put much light on the road. If your looking for a real upgrade, invest in a set of aftermarket driving/fog lights.
1. according to my owners manual the oem fog light on a b14 is 35 watts, not 55 watts. it's an h3 special. with slight modification
http://www.se-r.net/electrical/bright_lights.html you can install a regular 55 watt h3 bulb. the difference in light output is significant, but not dramatic, and will not melt your wiring. i performed this and the foglight rewire mod to my b14 a couple yrs ago.
2. i agree with looking @ aftermarket lights.
Ric
