Originally Posted by chris13bsr20
I didn't have anyone press them in. I used a floor jack positioned under a steel shelving thing... if there is a next time, I won't do it like this again! But yeah, they make a big diff and the vibration isn't that bad at all.
I just did mine yesterday. I go to college, so I am tight on $, so I didnt want to pay to get them pressed in, or out. What I did was after I burned out the mounts, I took a flathead and hammer to bend the ring out a little, then a chisel and hammer to cut the ring. Then I used another, bigger flat head to pop the fing out. Then to press the mounts in, I got a can white lithium spray grease and sprayed all over the inside of the mount, and the one side of the prothane. jacked my car up, put the mount under, and had someone lower the tire VERY slowly as I held the mount on centered(so it doesnt pop off). Once it was centered and tight, I got my hands out, and lowered the car almost all the way, and the mount popped right in! easy as hell!! Ghetto, but cheap and easy! I'm installing them in my car tomorrow prolly. I just put these in an extra set.
