Old 07-30-2006, 11:00 PM   #21 (permalink)
SoSideways
Hater of 240sx ASSHATS #2
Your USDM speedo is probably busted, thus no workie.
SoSideways is offline   Reply With Quote
Old 07-31-2006, 02:17 AM   #22 (permalink)
nsn240
sr20 240sx
Originally Posted by Rittmeister
1. Get USDM gauge cluster.
2. Take tach out of JDM cluster.
3. Put JDM tach in USDM cluster.
Now you have the speedo you want, an odometer that reads in miles, and the right tach for the SR.
You may have to give up on the digital cluster and go analog. The digital units are notoriously unreliable. This is widely known, and these issues could have been found through searching.
definately the easiest way to go about having a speedo and tach... but then that only reads to 115
89 240sx sr20de/t
pa-nissans.com
nsn240 is offline   Reply With Quote
Old 07-31-2006, 10:52 AM   #23 (permalink)
doluck
Waited to long for this
No, im using the digital one... I think it goes past 115
I have mastered the art of breaking sh*t!
6 motors down ... 1000's more to blow!
93 240, BlackTop, s14 turbo, Power Fc, Greddy intake manifold, pullys, Apexi GT Spec turbo back, Fever Racing turbo manifold, PWR intercooler, Koyo radiator, Spec stage 3 clutch, Nismo GTS LSD with fluid cooler, Tein HE, and so much more
doluck is offline   Reply With Quote
Old 07-31-2006, 11:59 PM   #24 (permalink)
nsn240
sr20 240sx
Oh, yea.. the hud goes to 299
Old 08-02-2006, 12:17 PM   #25 (permalink)
doluck
Yea .. to bad my car don't! I could stop saving up for the damn Bugatti Veyron!
Old 08-16-2006, 10:46 PM   #26 (permalink)
doluck
Hey if anyone wants to trade a JDM HUD for a norm. JDM, I'm down if you pay shipping!
Old 08-17-2006, 10:52 PM   #27 (permalink)
doluck
If I change to the Non HUD JDM cluster, do I need the harness or will the 240 non HUD harness work?
Old 08-17-2006, 11:01 PM   #28 (permalink)
bardabe
you wil need the HUD Sub Harness.
juanton: I swear dude
juanton: if this girl becomes my gf
juanton: I am shaving that sh*t
mark: haha
mark: just lick it man
mark: gotta start off hairy
mark: so you can feel way better
mark: when it's shaved
bardabe is offline   Reply With Quote
Old 08-17-2006, 11:10 PM   #29 (permalink)
doluck
to get rid of the HUD?
Old 11-10-2006, 02:26 PM   #30 (permalink)
Taiden
Luke Pighetti
Taiden's Avatar
One of you guys should wire up a switch to bypass the resistor. Make sure you pick a resistor that gives you the target resistance without adjusting the potentiometer. That way you have a switch similar to the switch on the Corvette C5 FRC... you push it, and it switches between kph and mph.
Old 01-29-2008, 08:37 PM   #31 (permalink)
Silver S13
S13 Speedo ... 180 ...
I'm new the the SR20 forum. On my S13 I have the electronic dash that can convert from km per/hr or mph and shows the image on the windshield. There is a name for that but I forgot what it is oh yeah HUD. With my current set up the fastest I have gone is 148mph I don't even know what my car is capable of yet since I just purchased it about two months ago. Does anyone else have the same dashboard?
Silver S13 is offline   Reply With Quote
Old 01-31-2008, 10:53 PM   #32 (permalink)
MarkSR20
Air filter cleaner masta
MarkSR20's Avatar
Trader Rating: 28 (100%)
I got 180kmh in mine... try figurin that out while ur doin it?!?
MarkSR20 is offline   Reply With Quote
Old 01-31-2008, 11:04 PM   #33 (permalink)
Rittmeister
The Groove Master
Rittmeister's Avatar
Many people have digital dash.
Most don't work. They're notorious for failures.
If you went 148mph, I'm assuming heavy mods? Especially since the stock ECU is limited to around 120?
1990 240SR - the DET has landed.
Kent's Funkay Disco
Rittmeister is online now   Reply With Quote
Old 02-01-2008, 12:39 AM   #34 (permalink)
paNX2K&SE-R
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 65 (100%)
What does that have to do with the price of rice in China?
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 02-01-2008, 03:13 PM   #35 (permalink)
Silver S13
180 kmh speedo ...
Yeah I have the Apexi Power FC with lots of bolt ons and the S15 turbo I think T-28. I brought the car with these mods but I am afraid of over-reving the motor because I don't think it has a rev limiter. The engine will go a little past 8000 RPM's which I don't think it is suppose to go to without a built head right. I shift at 6200-6500 but I need to get it tuning so I don't blow the motor.
Old 03-02-2008, 11:18 PM   #36 (permalink)
iworshiplemons
Just food for thought...while you're fu*king around with your wiring, you could make a cutoff switch for the speed sensor. No speed sensor, no speed governor... so just stick a switch inline with the speed sensor wire going to your ECU, and flip it when you want to go fast...
Once you're done killing yourself, flip it back on, your speedo will start working again, and your car will once again be limited...
Objective D
1992 SR20 Powered 240SX Hatch
Originally Posted by worrgames08
God forbid you have to find a vagina that is in high school
iworshiplemons is offline   Reply With Quote
Old 03-02-2008, 11:41 PM   #37 (permalink)
Rittmeister
The Groove Master
No speed sensor, no governor...
... no speedometer, no odometer. Arguably neither method is easier, but at least with the speedo-resistor method you can tell (roughly) how fast you're going.
