Old 09-04-2006, 04:19 PM   #1 (permalink)
NissanTuner
I hate 240sx owners
S13 SR20DE Install Thread
Edit
Raze: To destory, demolish, obliterate.
Project RaZe: The ongoing effort to destroy, demolish, and obliterate the competition.
RWD SR20DE 93 240SX Coupe.
Best all Time Quote:
FWD should really be spelled FTW
NissanTuner is offline   Reply With Quote
Old 09-04-2006, 06:59 PM   #2 (permalink)
98sr20ve
Couple thoughts.
1) You need to take care of the heater hoses that run behind the head before you put the engine in the car. You will need to buy adapter hoses from www.heavythrottle.com or adapt existing to work.
2
The two wire plug above the 4 wire plug in that picture is for the Knock Sensor. You can switch the plug with soldering pretty easily. Make sure you cut the plug off the KA harness very close to the plug so you have plenty of room to soldier a the SR plug on to it. Or swap the ka knock sensor onto the sr.
Steve
06 G35 6MT
Old 09-26-2006, 03:04 PM   #3 (permalink)
Opone
It looks simple, my car was a 1990 ka24e had to get wiring harness, just found out the day i joined about this thread.
its one of just a couple of reasons i joined.
Opone is offline   Reply With Quote
Old 06-26-2007, 09:05 PM   #4 (permalink)
oNyX_riddle
AWESOME WRITE UP!
oNyX_riddle is offline   Reply With Quote
Old 11-05-2007, 10:18 PM   #5 (permalink)
importkid
Is this pretty close to the same instruction as the SR20 DET??? except innercooler piping and etc..
importkid is offline   Reply With Quote
Old 11-05-2007, 10:33 PM   #6 (permalink)
McCoy I am a moderator
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 72 (100%)
The wiring is done differently. with the SR20DE swap you can retain the KA wiring harness mostly... with the DET you need to use the DET harness.
Old 11-06-2007, 12:12 AM   #7 (permalink)
importkid
are the wiring harness easy to find?
Old 04-28-2008, 10:48 AM   #8 (permalink)
sjsdperformance
Crush the Domestic Dino
if one was doing a sr20de swap into a 240sx could they use the sr20de harness and do the dash wiring and be all set
[IMG] http://sjsdperformance.cjb.net/sjsd.jpg [IMG]
sjsdperformance is offline   Reply With Quote
Old 06-03-2008, 03:16 PM   #9 (permalink)
GMMTC
Why is this post missing? I'm in desperate need of this information and it has been removed? Does anyone have the original post backed up somewhere?
GMMTC is offline   Reply With Quote
