Pattern marked:
After removing the glass, interior pieces, and brackets, I drilled holes up through the roof to get an idea where the sunroof frame was. Then I ground it down where the bit poked up through so i wouldn't cut myself when working with it. Next I marked a pattern with a Sharpie and tape measure.
Almost out:
Out!
I cleaned it up with a grinder and buffing wheel to get rid of the edges and loose metal.
The carcass:
I haven't had a chance to weigh it yet, but my guess is between 5 and 10 pounds.
Removing the spare tire bracket:
I used the same cutting wheel / grinder / buffing wheel combo to get this one out. I decided to do this now since there was no gas in the car, and therefore no chance for Andy to go boom-boom.
Stock radiator hose versus the Samco:
I didn't get a chance to install them yet as the 316SS t-bolt clamps I ordered were too large. :tears
Rear wiring harness in, before cleanup:
Rear wiring harness out:
Harness after cleanup:
I'm almost done with it here, as I have to connect it to the 3 chassis wires, attach the ground, and finish wrapping everything. I'll post some pix when finished.
