Old 09-12-2006, 10:27 PM   #381 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Originally Posted by nsn240
we need more updates!! haha
Not much in the way of pictures yet, but I can provide some commentary:
Oil leak appears to be minor, so the current plan is to continue driving the car until it gets worse. I took the car out for about 20 minutes this past Saturday, at which point I came home with sore ears from the noise. It isn't terrible when you aren't getting on the throttle, but becomes very loud when you do. I will definitely need to quiet the car down before attempting to autocross it, although I'm unsure if I want to find a used 3" catback and testpipe for $200(?) or build my own to save weight for $350.
This coming Saturday I'll swap the coolant reservoir out, re-bundle the wiring, reinstall the ECU and dash, and design a battery tie-down mechanism. Then it's off to get a few more kilometers on the clock and let my teammate get some time in behind the wheel. I will hopefully have some pictures at a minimum, but am still undecided about whether or not I want to drop $$ on a video capture card right now.
If you could get some pictures up up how the car sits that would be awesome, i'm probably gonna get the agx/tein combo here in the next month or so and id like to see how it makes the stance. thanks
I would be happy to oblige, but my car is gutted as hell and will sit higher than most.
-Andy
240SR track donkey
Old 09-20-2006, 02:38 AM   #382 (permalink)
brandonb012
i try!
8 days since a post...you all are killing me
91 240sx-
02 Blazer Extreme-Stock
05 Colorado-Stock
brandonb012 is offline   Reply With Quote
Old 09-20-2006, 06:00 PM   #383 (permalink)
rushmatic
^Kick Me^
im freakin dyin over here :LOL:
1990 Honda CR-X Si
rushmatic is offline   Reply With Quote
Old 09-20-2006, 08:22 PM   #384 (permalink)
Nismo_34
Project All High School!!
You do realize *** most of this forum revolves around this thread/epic adventure right?
White 91 SE-RR
My Car My Space
Nismo_34 is offline   Reply With Quote
Old 09-22-2006, 02:58 PM   #385 (permalink)
Shift_Munky
A.K.A. 2Fass240us
The following is copied from another forum that Casey also visits:
Originally Posted by sr20goofus
any updates on the break in?
I am getting about 20km on the car per 15-20 minutes of driving backroads once per weekend. I am doing about 75% throttle since I don't have the gas pedal stop in place yet, and bumping my RPM ceiling up incrementally until I hit 50-ish miles at which point I'll take it all the way to redline. After that, I'm taking it back to the dyno for a baseline curve and to see if the A/F is doing anything silly through the rev range.
No Auto-X plans yet?
I plan to attend an autocross at Knight's Stadium on November 12. I will have to use sub-par tires because I don't have the $$ right now for good ones, but it'll still be good to get out there.
Leaks delt with or just left alone to continue leaking?
I am keeping an eye on the oil leak and oil level, but plan to leave it alone unless it gets worse. It really isn't bad, and usually only gets a very slight film from the leak point to the interface with the upper oil pan. At this point it isn't worth the effort to tear half the engine apart to fix it, only to have it spring up again as it has for so many other SR owners.
Seat-belts found and/or installed yet?
I found some seatbelts from a B14 200SX at a Pull-a-Part and modified them to work. I will do a write-up on this later, but it's pretty easy. You just cut a tab off and slot the upper chassis hole
How's 10 strike ya?
Meh, I'm doing OK.
ORLY? That's flippin sweet, I'm honored.
Sorry guys for not posting something up by now, but work and life have both been ridiculously busy lately. I should have an update by Monday at the latest.
-Andy
Old 09-22-2006, 03:19 PM   #386 (permalink)
Nismo_34
MONDAY!! MONDAY!! MONDAY!! Woohoo it's like christmas
Old 09-25-2006, 09:35 AM   #387 (permalink)
johnnyg82
Need to get an SE-R soon
It's monday!!! *waits in anticipation*
1991 Sunbrid well, it was free
1995 200SX SE-R deal fell through, ggrrrr!
<img src="http://www.danasoft.com/sig/Radyum.jpg">
johnnyg82 is offline   Reply With Quote
Old 09-25-2006, 07:44 PM   #388 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Working on it now. Will have something soon.
Old 10-01-2006, 10:08 PM   #389 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Original positive cable:
Red double plug:
I ended up cutting both of the side tabs off to get it to work with the new clamps.
Revamped negative cable:
Modified the postive cable to remove the stock clamp and open up the hole:
PC680 still putting out 12V after sitting on a shelf for 2.5 years:
Car at P1 Auto waiting for electrical troubleshooting:
Pulling the valve cover to make sure the CAS is aligned properly:
Old 10-02-2006, 01:57 PM   #390 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Seat belts from a 1995 200SX:
Me demonstrating the tab that needs to be removed:
About to notch the upper hole to accomodate seat belt installation:
All hardware installed on the passenger side:
Finished installation on the driver side:
Cool shot while I worked on the seatbelts:
New coolant reservoir:
Old 10-02-2006, 03:26 PM   #391 (permalink)
Nismo_34
Woohoo! It's on Monday that's for sure.
I wonder if those 200sx belts would fit on my b13?
Old 10-02-2006, 11:55 PM   #392 (permalink)
Turbo711
[Sorry] Edit: I've decided to follow your lead and completely strip my car down to the bare chassis. Mainly because I'm in college and it's going to take forever to do anything. Nice belt job and I love those hood latches, Top Secret right?
S13 parts for sale.
I need a daily, not a project.
Turbo711 is offline   Reply With Quote
Old 10-03-2006, 08:57 AM   #393 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Originally Posted by Turbo711
Monday?!?!
Yeah, I promised to have pictures by last Monday and was a week late delivering.
Hmmm, I dunno. S14 seatbelts work in a S13, I found that B14 ones will work in a S13 with some modification. So...maybe? Best thing to do is look at the mechanism and attachment points and make an educated guess.
I've decided to follow your lead and completely redo mine. Mainly because I'm in college and it's going to take forever to do anything. Nice belt job and I love those hood latches and the pic above.
Completely redo your what?
I was stoked that the belts work because I only paid $15 for them at a junkyard and people normally ask $50-100, and the Japanese S13 ones go for $100 as well. So for a little bit of effort I was able to save quite a bit of $$. Only caveat is that I didn't have to worry about interior panels, which seems to be the snag for most people.
As for the latches, I've received a lot of compliments on those. I'm a huge fan because:
1) They're flush and very attractive versus the standard "Sparco-style" ones,
2) They are lockable (and not easily circumvented), and
3) The body is an engineered thermosplastic and the mechanism gives me a stiffy.
The downside? They're ~$100 per pair. But I think it well worth it for a purpose-built racecar. Hell, they'd even be nice for a street car. In fact, I'm quite surprised I haven't seen more of them out there, especially on show cars where appearance is so important. Oh well, I don't mind being a pioneer.
-Andy
Old 10-06-2006, 07:59 AM   #394 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Finally uploaded a video of the car running a few days after it was first started. Quality was a lot better before it was Googlized. Make sure to turn the volume up!
-Andy
Old 10-06-2006, 12:23 PM   #395 (permalink)
Nismo_34
Nice. Sounds awsome. Is there no exhaust on.
Old 10-06-2006, 02:29 PM   #396 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Thanks. Not yet, no. I am supposed to meet with an exhaust guy soon.
-Andy
Old 10-18-2006, 02:05 AM   #397 (permalink)
brandonb012
i try!
have you got the electrical problems worked out yet?
Old 10-18-2006, 10:07 AM   #398 (permalink)
Shift_Munky
A.K.A. 2Fass240us
Yes, they've been worked out for 1-2 months now. I posted the above material late, after the elclectrical problems were already resolved.
I had an issue with the brake lights coming on, but it wasn't electrical in nature. There's a small rubber stop that depresses a button, sending a signal to the brake lights to come on. This rubber piece fell out, and I *temporarilty* replaced it with a piece of cork from Home Depot. Works great, shouldn't degrade that much, and I doubt it'll come out.
-Andy
