finally! my car - Page 9 - SR20 Forum
Old 12-04-2005, 09:14 PM   #161 (permalink)
A.K.A. 2Fass240us
Originally Posted by SRkoryDET
for future reference greddy.com does have guage wiring diagrams in plain old english on their site now
Link please? I went back and still couldn't find them.
i envy your work but have to ask why you went strut/shock rather than just buying coilovers? i mean since you went through all that trouble blasting and spraying the various suspension parts ya might as well go for the gold and not waste money on kyb (barf). hope to see your end product soon. laters and good luck.
Purely cost, plus this setup has shown to be a suitable one for beginner drivers. My plan was to start with a less expensive setup, build my skills as a driver until I can outdrive them, cage the car, and then go with a nice coilover setup.
240SR track donkey
Old 12-05-2005, 05:12 AM   #162 (permalink)
RS13 power
that's good thinking. recommend the jic magic flta1's and flta2's (2's if it is really gonna be a track star)
K.Ogawa is offline   Reply With Quote
Old 12-05-2005, 01:02 PM   #163 (permalink)
A.K.A. 2Fass240us
This is an option, although I've heard their stateside customer service really sucks. "Rebuildability" is a major concern since I don't want to have to drop $2k+ every time they need to be rebuilt just to get brand new units.
For this reason, I am currently leaning toward Tein RS's or Ground Control Advance Designs. I had the latter on my Civic hatch, and they are amazing. Customer service was great, rebuilding is easy, and the construction was top-notch. I would also consider an offering from Koni if I were made aware of one in this range.
Ultimately I will know my ride height within 0.5 - 1", and have a spring rate and damping rates nailed down, so I only have to specify these things to (for instance) Koni and have them build something to my specifications. Off-the-shelf will have to do until I get to this point though.
-Andy
Old 12-06-2005, 09:06 AM   #164 (permalink)
Hey, hope the buildup is still goin smooth, thought you might like to see this setup I came across on Driftsession. It's kinda like a front mount combined with a V-mount, so it has the short pipes. Oh and you don't have to notch the radiator support.
Ouch, I think I would cry!
Turbo711 is offline   Reply With Quote
Old 12-06-2005, 10:09 AM   #165 (permalink)
A.K.A. 2Fass240us
I can kinda see what the design looks like, but the picture is small and doesn't focus on the area of interest. Any more pictures?
Old 12-07-2005, 08:52 AM   #166 (permalink)
Theirs one more, but it's not too detailed either. Here it is:
The intercooler is under the air guide, and the pipes run into/out the very ends of it. Both the radiator and iintercooler are tilted backwards.
Old 12-07-2005, 11:03 AM   #167 (permalink)
A.K.A. 2Fass240us
That helps a little bit, actually. Thanks.
Update: Russ will definitely be coming up this weekend to help finish the wiring, including the fuel pump. After that, I only have to purchase and install the lower radiator hose, find and install a few other small hose bits, and add oil to the engine and tranny. Wish me luck!
Old 12-18-2005, 11:57 PM   #168 (permalink)
sr20 240sx
i have a friend that had the exact same setup (intercooler setup) with his td06... i can get some pictures if you want
89 240sx sr20de/t
pa-nissans.com
nsn240 is offline   Reply With Quote
Old 12-19-2005, 11:23 AM   #169 (permalink)
A.K.A. 2Fass240us
Yes, please do.
Old 12-19-2005, 01:45 PM   #170 (permalink)
A.K.A. 2Fass240us
Fuel filter bracket, painted:
Installed:
GReddy radiator cap:
SMIC, begging to be mounted:
SMIC brackets after beadblasting:
Too bad I still can't figure out how to mount the whole thing to the chassis. :tears
Alternator /starter /etc. sub-harness, before stripping:
After:
All the SR harness(es) wires that were removed:
New wire routing underneath intake manifold to keep things clean:
How tidy!
Interior cleanup in progress:
Old 12-19-2005, 03:16 PM   #171 (permalink)
Forever slow
Feedback Score: 4 reviews
damn that engine bay is clean. good job man! keep it up!
#1 -1993 Classic XE SOLD
#2 -1992 Classic SE-R SOLD to Autoxse-r
#3 -1993 Classic SE-R SOLD
-2002 GMC Sonoma 4.3 V6 - The DD
-1988 Kawasaki EX500 - The newest money trap
Is it Possible to use a TMIC and FMIC?!?
intiractive is offline   Reply With Quote
Old 12-28-2005, 02:59 PM   #172 (permalink)
A.K.A. 2Fass240us
NEW PIKTARZ!!!
Russ’s wiring job:
Test-fitting the dash:
I did this to determine boost and oil pressure gauge mounting location, in addition to determining which brackets I needed to keep.
Removing those I didn’t:
The GReddy control units mounted and about to be connected to the sending units:
Using some 8mm silicone vacuum tubing to make the connection:
I’m not sure if silicone will work here, as it’s incompatible with gasoline and oil. Any thoughts?
Running the wiring from the control units to the gauges:
Another one of Jordan’s artsy shots, this time with a lensbaby:
Old 12-28-2005, 04:02 PM   #173 (permalink)
bla bla bla
I don't know about the rest of you guys, I just can't get enough of these pictures! I love getting the notification email that there are more up
2003 VW gti 1.8t
72 Datsun 510-sold
Old 12-28-2005, 04:33 PM   #174 (permalink)
A.K.A. 2Fass240us
Glad to hear you're enjoying them.
"You've got mail."
Old 12-28-2005, 05:04 PM   #175 (permalink)
tight project you got going. loving the pics
good luck
SrpoweredRPS13 is offline   Reply With Quote
Old 12-28-2005, 09:53 PM   #176 (permalink)
sr20 240sx
here's the picture i have of it... the IC sits right in front of the radiator (yes, his welding was ugly when he made that piping):
Also, where did you order all your blue vaccuum hosing from (coolant overflow tube too)
-aaron b
Old 12-28-2005, 11:13 PM   #177 (permalink)
A.K.A. 2Fass240us
RoadRace Engineering, in the "DIY" section. Mainly a DSM group from what I can tell, but they have everything in stock that I've needed. I originally wanted to do black for the tubing, but it's too damned hard to come by. The blue isn't too bad...it's actually starting to grow on me.
Old 12-29-2005, 09:29 PM   #178 (permalink)
sr20 240sx
sweet, thanks for the link. they do carry black (woot! thats what i was looking for) did you use the 3mm for the vacuum connections?
Old 12-29-2005, 10:20 PM   #179 (permalink)
A.K.A. 2Fass240us
Depends on the vacuum connection in question. After talking with the head guy (don't remember his name) at RRE, he offered to name a vacuum hose kit after me like he did with the DSM one on their site if I could come up with the lengths and diameters of tubing in question. Let me dig through my notes to see what I can come up with.
-Andy
Old 12-30-2005, 01:02 AM   #180 (permalink)
Forever slow
shiftmunky... that line on the vc to the vacuum line, the silicone hose... well you will get small amounts of oil. i would run it, then check it later that day to assess how much came through there.
