Old 12-19-2004, 06:33 AM   #1 (permalink)
bjorkluv
Force Fed
How To: SR20DET Fuel System Upgrade
With the help of Ryan S-14, I did a pretty big Fuel System Upgrade today. As seen in the Pic, I installed a Walbro 255LP Fuel Pump, NISMO FPR, and a Fuel pressure Guage.
First things first, with the car running, remove the fuel pump fuse and let the car die out.
Let’s do the Fuel Pump first. This was easier than changing the oil in my opinion. In my specific car, the Fuel pump is easy to get to, it’s in the trunk. Juts lift the cover for the spare tire well and remove the bolts that cover the Fuel Pump carrier/harness. Then disconnect the wire harness that is connected to the Fuel Pump carrier. Yeah it is a bit dirty in there:
Before you can remove the pump you have to take out the (2) fuel lines, don’t lose the clamps, on my car if I wasn’t carefull, they would be gone forever…Be carfull when removing the Pump from the gas tank as not to damage the fuel level Bobber, you gotta turn it this way and that way but eventually it will come out. Also do not let any of that dirt fall in, that would be the sucky..Make sure you cover the hole to the gas tank with a magazine or newpaper so no debris can get in there. Once you have the Fuel Pump carrier out you can ensure the new pump you have is supplied with a power wire and a ground wire..if it is then you can cut the stock wires off, leaving enough to splice in with the new pumps wire harness for power and ground. Here is a pic of them together after, the red and black wires are the ones you cut:
If your new pump does not come with fuel line, buy some..it’s best to use new line. After you cut the old wires, set the new pump in the carrier…When you put the new fuel sack on, there is a little washer that holds the sock on the pump, be carefull with this thing as it is fragile and the only thing that holds the sock on the pump. Then put the rubber grommet over the sock and it is rady for the carrier…After the pump is in the carrier try to get it in as tight asyou can, using the fuel line to move it up and down, this way you can force the pump to stay in the carrier..Some people use zipties to get it tight. I didn’t need to, it fit nice and snug.
Then splice the power and ground wires from the new pump harness to the carriers wires…
Then it should look like this:
After that, just put it back in using the reverse order.
Pointers:
Don’t smoke till your done!
bjorkluv is offline   Reply With Quote
Old 12-19-2004, 06:34 AM   #2 (permalink)
bjorkluv
Force Fed
Fuel Pressure Regulator and Gauge:
Not much to write on this, pretty much in and out, but I will cover a few pointers:
This is the old FPR, set to stock settings at 3 Bar:
You will have to take out the Fuel line from the Filter to the Fuel Rail, and the Fuel Line that returns to the Fuel Pump from the old FPR. Again a pointer is to use all new line. These lines are on pretty tight, infact I had to cut the lines that went to the Fuel Rail. Also since I was installing a Fuel Pressure Gauge as well, remember you will need more clamps than you had before, I had to go to the store and buy 2 more.
Once all the lines are off, and all the gas spilled everywhere and you weren’t smoking, you can disconnect the vacuum line on the old FPR and take off the (2) bolts that hold it in. I saved the old one for the heck of it. E B A Y!
For the Fuel Pressure gauge, your fittings may be quite large compared to the Line. In my case they were and I had to run hot water over the line for 10 minutes to get it soft enough to fit over the fittings.. Here is a PIC after I had them on, remember those new clamps? Well here is where I figured out that I didn’t have enough:
Also put some Teflon tape on the threads of the gauge to make a vacuum seal like this:
Now back to the FPR, pretty easy just use the (2) bolts to re attach in the old placement spot. Then connect the fuel lines back up to the filter, FPR, and Fuel rail. You’re done.
Make sure that if you do not have a good short-term memory, that you take a picture of the old lines to make sure you have them right.
Here is a final PIC
Setting the Fuel Pressure is a problem on this blacktop. With my accessories on I can set it at 58 PSI or 4 Bar, once I start the car and it cycles for a few seconds, it reads 3 bar. Weird. I am trouble shooting this now. Also my FPR when I pivot it I can hear a small vacuum leak if I move it hard enough. This shouldn’t happen so I went back to the dealer I bought it from and he is calling NISMO to see if the top twisting and releasing vacuum is a problem, then he will give me a new one,D U H…it’s a problem but I can wait since it doesn’t lose vacuum unless I force it..They also told me they have to ask NISMO if on a Turbo application setting the pressure has a deviation once the car is running…I know someone is going to say disconnect the vacuum line on the FPR when setting the pressure. Tried that too. Its goes back to 3 bar, well the gauge at least. But when I first start it, and when the accessories are only on, it reads what I set it at. Once the Pump primes I go back to 3 Bar. So I will not up the boost until I figure this out.
Late
Daryl
Old 12-19-2004, 12:58 PM   #3 (permalink)
trinispeed
Trader Rating: 17 (100%)
excellent write up man, picture and detailed explaination.
One pont though fuel AKA gas eats teflon tape, you might want to use paste to prevent leaks.good luck figuring out you fuel pressure problwm maybe more knowledgeable will chime in
trini
Car shopping made easy! We do the work for you while you save time, money, and hassles! Visit us at Personal auto brokers.com
Karting Vist............www.Torontokartstands.com
trinispeed is offline   Reply With Quote
Old 12-19-2004, 03:48 PM   #4 (permalink)
bjorkluv
Force Fed
trini
Yeah the fuel pressure problem will hopefully be answered by NISMO today when this guy calls..if not I will at least tell them I want a new FPR to try out...
Thanks
Daryl
Old 12-20-2004, 01:07 PM   #5 (permalink)
Mr Sentra
Keeping It Real
Great job again Daryl.
Marvin
B15 SE TURBOCHARGED
Mr Sentra is offline   Reply With Quote
Old 12-20-2004, 01:58 PM   #6 (permalink)
CarloSR
Just have one comment: change the fuel pump tank gasket or you'll never be able to fill the tank again.
Good write up.
Nissan Primera 2001 Turbo - Daily
Nissan 240SX RPS13 Turbo - Track drifter
Subaru Legacy H6 2005 AWD - Boxer AWD madness
CarloSR is offline   Reply With Quote
Old 12-20-2004, 03:03 PM   #7 (permalink)
Serban I am a moderator
Nice gauge
'93 NX2000: SR20VE
Old 12-20-2004, 06:55 PM   #8 (permalink)
bjorkluv
Force Fed
Originally Posted by Serban
Nice gauge
you must have been the florida hook up...thanks man
finally got the fuel pressure problem figured out..had a vaccum leak
also the first time I set it I didnt have it at operating Temp.
Late
Daryl
Old 12-20-2004, 10:23 PM   #9 (permalink)
Yeah, I'm the FL hookup. I told Ryan to buy like 10-15 gauges at a time and sell em in Japan, he can make some loot.
BTW, nice write up
Old 01-22-2006, 09:44 PM   #10 (permalink)
RYAN_S-14 I am a moderator
NISSAN ADDICT
RYAN_S-14's Avatar
Trader Rating: 19 (100%)
Stick, Stick!
RYAN_S-14
WWW.FLORIDASR20S.COM
RYAN_S-14 is offline   Reply With Quote
Old 09-08-2006, 12:51 PM   #11 (permalink)
nsn240
sr20 240sx
BTW, nice write up
you have any more of those you'd like to sell?
Awesome writeup... im gonna try and get this done in the next few weeks
89 240sx sr20de/t
pa-nissans.com
nsn240 is offline   Reply With Quote
Old 09-08-2006, 01:12 PM   #12 (permalink)
Sure do...go to www.gofastdepot.com they're on the front page, just scroll down a bit.
Old 03-13-2007, 10:03 AM   #13 (permalink)
whiplash willy
98 S13 Blacktop
What hooks up to the nipple on the upper part of the FPR? What is the stock setting in PSI for the SR?
whiplash willy is offline   Reply With Quote
Old 03-13-2007, 10:12 AM   #14 (permalink)
NISSAN ADDICT
RYAN_S-14's Avatar
the vaccum line from the upper intake manifold
stock is 3 bar
Old 03-16-2007, 04:01 PM   #15 (permalink)
whiplash willy
98 S13 Blacktop
What is the proper method of adjusting the Fuel Pressure? Do you just adjust it when the car is idling? Also I heard from one person the stock pressure setting is PSI is 30-32. Another person said 36psi. Which is it?
Old 04-24-2007, 10:48 PM   #16 (permalink)
nothingfancy
how do u adjust the fuel pressure? is there a screw or somethin on the new FPR? sorry im a newbie to these FPR';s and i would like to get 1
nothingfancy is offline   Reply With Quote
