They are more crucial with a heavily modded engine. If you have a regular (SSAC, HS gen 5 etc) header, you would be find dropping S3s or S4s in. If you had a DE with C3s and a HS gen 6, it would definitely be worth your while to tune the cam timing. It's a bit of a pain in the ass as you have to remove the valve cover each time you change settings
