» Auto Resources
Find new Nissan car reviews on Nissan Maxima, Nissan 350Z, and more. View pictures and guides on Nissan cars like a Nissan Altima.
» Sponsor Links
»Garage Storage and Cabinets
Old 05-11-2006, 09:54 AM   #1 (permalink)
Professor Dingbat
Very disappointing dyno results. Any ideas?
Last year we made 185 WHP with a stock high mile bottom end, S5s, Gen 6 header, ported head and calumsult ECU tuning.
Over the winter we built up a new motor. the specs are:
300ZX pistons
same head as last year, but added supertech valves, RR lifters, '98 rocker arms, double guides on the valve shims for valvetrain stability
C3 cams
O2 induction intake manifold (same as the one 'Dre used 4 years ago, it made him 8hp with a similar setup)
Gen 6 header
ECU tuning (tuned to ~13:1 AFR).
We went to the dyno yesterday and no matter what, the car would not make more than 155WHP
The power is peaking at 6700RPM and falling off hard.
I am really baffled, as the only differences from last year are the cams, built bottom end and intake manifold (all which have been proven to work) and somehow I am down 30hp, when I should have gained 15-25hp.
I did not play with the cam timing. It is just too far out from what it should be (power wise) to have cam timing make 25% more power.
Any ideas?
Old 05-11-2006, 10:56 AM   #2 (permalink)
SR20 Racer/Tuner,Gamer
down 30 hp when you should have 20 more thats weird!
thats a lot of loss,im sure someone here can figure this out and gain back your 50hp
-->NX2000 91(race car)
-Taylor 10.4mm wires (Thanks XxToKeSxX )
-Cusco strut bar-K-sport coil-over-Whiteline LCA
-Toyo RA1 and Hankook Z2000 -SSAC header 2.5
-Custom CAI -Custom 2.5 inch exh. mandrell bend+Magnaflow 2.75
NX 2.0 is offline   Reply With Quote
Old 05-11-2006, 11:33 AM   #3 (permalink)
Any ideas?
it's got to be a timing issue. who tuned it?
oneSIX is offline   Reply With Quote
Old 05-11-2006, 11:48 AM   #4 (permalink)
done
if power is peaking early, then there is a timing or air flow issue. the cams could be advanced a lot, poorly ported head, poor intake flow, or something of the sort.
Old 05-11-2006, 04:41 PM   #5 (permalink)
Import Tech.
make 100% sure you dont have a cam thats a tooth off !!
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
Old 05-11-2006, 07:36 PM   #6 (permalink)
Making the G breathe hard
Jaketips42's Avatar
You can't just put double guides on you valves? Can you? I just shimmed my set because I know thy have to be level. Thought I'd ask...
Old 05-11-2006, 09:09 PM   #7 (permalink)
wes
712 ways to be a dick!
wes's Avatar
Trader Rating: 27 (100%)
I would dyno throuhg the stock intake manifold just for comparison sake. That and make sure the cam timing, base timing is set right!
my site
Old 05-11-2006, 09:13 PM   #8 (permalink)
i love b13's !
Trader Rating: 22 (100%)
yeah look at the cam timing and the ignition timing. thats way to low.
u as most of us know some things dont work together but the said set up should out due the prior set up.
considering you have higher compression pistons with a 1mm bigger bore, bigger cams and a 02 mani you should be blowing your previous numbers away.
good luck man, id like to know what she puts down when u get the bugs worked out.
one hell of a motor u got there.
stratton.
im back.......
Old 05-11-2006, 11:10 PM   #9 (permalink)
Professor Dingbat
Yoshio, in Toronto. He has tuned 100's of cars. We started using our Calumsult ECU but for some reason it would not burn new chips A car we compete against went to him and made 187 WHP with a gen 5 header and stock intake manifold.
The head is the same one we used last year. It made ~10HP when we swapped it on last year.
It has a 63mm throttle body, 3" intake pipe and JWT POP. Same as last year.
I assembled this motor myself with a brand new timing chain. I am pretty sure it is correct, although I could always check. Big PITA to pull the timing chain cover though.
Old 05-11-2006, 11:13 PM   #10 (permalink)
Professor Dingbat
Good observation. I had the machine shop file down the valves so the stems are at the exact same height. I also had to modify the rocker arms slightly so the right side of the rocker arm would fit inside the guide.
Base timing was 20°, but Yoshio set up the computer for 20° base. He tried a few maps, it made a bit of a difference, a few hp but after the tuning we were still at 155WHP.
Old 05-12-2006, 12:24 AM   #11 (permalink)
fan boys suck!!!
dont s series cams like it at stock timing not advance been your at 20??? when stock is like 13-15?
HEY ALBERT PANZIE!!!! all i gotta say is....
15.135 @ 92.63mph and 15.318 @ 93.82mph...nuff said..no rhymes needed here to poet your a** haha
dJ gNO cYDZ.................. RIP DJ SPEEDY!!!!!!!!!!!!!!
gEE805 is offline   Reply With Quote
Old 05-12-2006, 12:35 AM   #12 (permalink)
Small, Blue, and Slow!
Just thought I'd throw this one in there, but are you using the same dyno as you did the first time and has it been recently calibrated?
1998 Nissan Sentra SE
Mods: SS AC Header, SP1 catback, AEM CAI, Hypercos, AGX, ME mounts, 22VFs, Bobcats, Powerslot, SS lines, Fidanza Fly, ACT clutch, UR Pullies, B&M shifter
Rami is offline   Reply With Quote
Old 05-12-2006, 12:35 AM   #13 (permalink)
Professor Dingbat
Actually, JWT's map for C3 cams is 25° base. This was a custom ECU program, so the base timing is up to the tuner.
Old 05-12-2006, 02:01 AM   #14 (permalink)
you know everything...NOT
why tuning for 13:1 a/f ratio? i would think you would want closer to stoichiometry.
93' SE-R
tre fidde is offline   Reply With Quote
Old 05-12-2006, 05:06 AM   #15 (permalink)
SSS
When you had the s5 cas installed, was the head ported for the most efficient flow for the s5's? If this is the case, then that could be the reason why you are not getting the power output you should be getting, because the head is not flowwing as efficiently with the c3 cams.
2Shots' is offline   Reply With Quote
Old 05-12-2006, 08:41 PM   #16 (permalink)
Stop beeing lazy!
ur not going to get a miracle awnser!
Make shure ur Throttle sensor and all is correct!
Then swap back the S5's and go do a power run! it would be the only way into finding the problem! Cams on these engines tend to be very picky! test it!
Only then ull know! swopping the cams should take longer than 1-2 Hours!
NissanSti200 is offline   Reply With Quote
Old 05-13-2006, 01:55 AM   #17 (permalink)
Professor Dingbat
Stop beeing lazy!
I just spent four fukcing hours on the dyno. I was up past 4AM every night last week getting this thing running and made it into work for 8AM. Don't call me lazy
I don't have the S5s anymore. A cam change shouldnt be more than 40 minutes,
I have come to the conclusion that the cam timing must be off. I need to find a way to degree the engine, but I don't even know where I should be setting the lobe centres. I'll email JWT and see what they recommend.
Old 05-13-2006, 04:05 AM   #18 (permalink)
Blast From The Past...
Trader Rating: 23 (100%)
I hope you're able to fix/correct all the bug's and get the motor running right. Because I really would like to know what your setup will put down?!
Eric?!
Support your Forum & Vendor's
SUPER"FAKA"MAN is offline   Reply With Quote
Old 05-13-2006, 07:17 AM   #19 (permalink)
Great! hope u get it right!@
Old 05-13-2006, 08:09 AM   #20 (permalink)
54C PWNS ME
I say the problem lies within tuning of the timing, and cams. 30whp is like wtf. Also like before mentioned, maybe the head and cams arent working well. imo 195-200 hp is realistic for this setup depending on how high you rev the engine.
1993 NX2000
JimmyNX2000 is offline   Reply With Quote
Refbacks are <
