Old 02-19-2007, 02:56 AM   #1 (permalink)
running mo' tings
n/a spark plug gap
my motor is running a msd 6a ignition w/ ss blaster coil. had it for about well over a year. i was wondering if it would run better increasing the gap more, lowering it or leave it where it is. its set at 0.40 now.
Tonynissan is offline   Reply With Quote
Old 02-19-2007, 08:02 AM   #2 (permalink)
NXTACY
i'm only running a Crane Cams LX91 coil with 1.4mm plug gap and no misfires.... runs smoother actually. i dare say you can run at least 1.5mm
-~10.8:1 CR (2mm Shave) + 17° timing
-WAI: Aluminium Intake w/ OBX Foam POD
-Hurricane Headers w/ 1.75' Secondaries
-2.5' Mandrel Bent Cat Back system.
-KYB GR2 Struts on Stock Springs
-Prothane Motor Mount Inserts
-NGK Iridiums (BR6) + Top Gun 8mm Leads
-Shortshifter + Nismo GK
- Crane LX91 Ignition Coil
-Adj. FPR @ 45psi Vac On
-JDM Inlet Manifold (No EGR!!!)
dsp26 is offline   Reply With Quote
Old 02-19-2007, 11:05 AM   #3 (permalink)
running mo' tings
from what i heard that you could run a larger gap cause of the additional spark thats coming from the coil. i think it might cause up start and idle problems. im not sure if its true or not.
Old 02-22-2007, 09:34 AM   #4 (permalink)
i am also to try increasing gap size on my ignition too
but yes, 1.5mm was said to work very well with these upgraded ignitions
i am running a msd dig 6 and a blaster hvc II coil
stronger the coil, more gap u can run but also the bigger the gap the more strain on the coil
sleeper14 is offline   Reply With Quote
Old 02-22-2007, 07:32 PM   #5 (permalink)
NXTACY
i've yet to find the article but the stock coil is apparently good to 1.3mm
Old 02-22-2007, 09:25 PM   #6 (permalink)
Import Tech.
I run all my NA motors at .047in. ... 1.2mm ..even with stock ignitions , always seen gains ... dang I used to run the Altima at .050in at the track ...Bone stock ignition with NGK wires and BKR7E-11 plugs ...never once had any issues ...
SHAWN
Ger-Brock Performance
Portland OR.
'98 Sentra SE.. Time Attack
'06 Pathfinder SE
'93 Infiniti G20 5spd.
My Nissan Site !!
Old 02-23-2007, 01:19 AM   #7 (permalink)
running mo' tings
ok so basically what your saying is that its ok to run a bigger gap w/o any misfire issues. what gain do you get when you increase the gap from 0.040 - 0.047 plus in addition w/ the advanced timing?
Old 02-27-2007, 01:00 PM   #8 (permalink)
u expose more flame to the mix
Old 03-07-2007, 03:54 PM   #9 (permalink)
banned
TRY INDEXING =0P
MaSERup is offline   Reply With Quote
Old 03-09-2007, 02:56 PM   #10 (permalink)
65 lbs/min of Fury.......
BKR7EIX-11 @ 0.047"
SR20DE with SR16VE pistons.... 11.85:1 CR
Edit 1: I forgot one thing... my plugs were supposed to have a 0.044" gap but when we took them out they were @ 0.034", the same thing happened to a friend of mine, why is that??? any ideas??
Edit 2: I extracted this from NGK web page: "...Another consideration that should be taken into account is the extent of any modifications that you may have made to the engine. As an example, when you raise compression or add forced induction (a turbo system, nitrous or supercharger kit) you must reduce the gap (about .004" for every 50 hp you add). However, when you add a high power ignition system (such as those offered by MSD, Crane, Nology) you can open the gap from .002-.005".
That means I'm going the wrong way, I should reduce the gap to 0.040" instead of increase it to 0.047"
Edit 3: now 0.039" and its better, I think I'll close the gap a little more
Club Nismo Peru
http://www.clubnismoperu.net
In the quest for 500+ whp...
Master_Sentra is offline   Reply With Quote
Old 05-13-2007, 03:38 PM   #11 (permalink)
bitemyshinymetalass
SuperblackZ's Avatar
My '91 B13 DE has N/A high compression JDM motor, bought plugs and they are pre-gapped for ~0.045". Seems large - any recommendations?
Current plugs are toast, just worn (NGK-R's). Notable engine is running rough at idle, even stays at 800-900 rpm but isn't smooth as everywhere else.
thx in advance
SuperblackZ is offline   Reply With Quote
Old 05-13-2007, 03:59 PM   #12 (permalink)
bitemyshinymetalass
oops - forgot, coil is stock so far as I can tell, but has JWT ECU
Former SCC Project SE-R
'91 B13 Black, JDM 10:1 CR SR20DE, Custom Intake/MAF w/JWT PopChg, 2.5" SSAC Header, Progress CO's 350F/250R, 3-way adj. 30-mm Progress FSWB, 22-mm Progress Rear Sway, Ground Control Plates, FSTB + FW triang braces, Progress LCA Brace, Energy Susp. bushings, Wilwood Brakes, Motgei Traklites 15x7", Kuhmo MX, RSTB w/triang trunk braces, R32 Steering Wheel
Team Progress
