Ok im goin with BC STAGE 2's i have a couple of items that might help or not help in this field for tunning purposes
S-ITC which is outdate an i think the highest timing you can go with it is 17'degrees advanced
Old school blue screen S-AFC
HKS 272 exhaust cam...
note** this is on stock ecu,springs,retainers,rocker arms
now the hks cam i just threw in there only if you guys think it would help out the HP with having the BC intake cam.. if not i wont do it also id like to know if the hks cams needs springs an retainers with the stock rev limit of 7,500k
i think the s-itc on a dyno might help out the tune a bit but its so outdated who knows..
s-afc will help on idle an tuning but *** if stock ECU with timing advanced all the way on zylene an 93 octane would suffice my apetite i rather try that..
let me know what you guys think...
Danny GDM (HKS)
1993 PRiMERA GT
I recently Installed BC Stage 3 and SR combo and find out that I hit the fuel cut too fast on 2nd gear so i decided to get a custom ecu tuned with a 8,000 fuel cut. You will get more all arround power with stock ecu with 21deg advance with 93 octane gasoline and you can tune the AFR with the S-AFC at least thats what I did before the custom ecu.....
By the way the best ET without cams was 14.39@93.8 and with cams and custom ecu 13.82@98.20
Hey Payu what was done to your motor inernally beside those cams and s/r kit if any?
i wondered in the bc intake cam with cam gear advanced 2 degrees would work nicely on 272 hks exhuast cam with stock cam gear.
on stock 7500rpm rev lmit
