I made 143.9whp and 130.3lbs/ft. of torque at 5800rpm. My torque band peaks out at 144lbs./ft. @ 5300 rpm. Is there an explanation for why this is? My mods:
CAI with HKS super Mega-flow, Hotshot Gen. 3, Magnaflow muffler, and timing advance. The ECU is stock. Mobil One was the lubricant and I had BP 93 Octane Gas. Let me know what you guys think. Thanks.
dudes those numbers are hard to believe for me, I've got and SR20DE highport red top engine eGT trim, i put the S3 and headers and all 2.25 free flow exhaust system and the difference from stock is very very small i think something is wrong or just those numbers are not correct i run the car with some advance timing and 100 octane fuel, the engine is about 20k miles on it i don't have dyno number but i think its no more than 130 horses on the wheels or may be less
try changing your fuel pump...or check if the fuel pressure is where it should be.. if you have the air+petrol=power! lol.....
check your timing or put your car on a consult to check if there is any errors...
10x a lot the car has very very simple ECU its not like the US spec, the engine stock is without anything ecological, there's no cat, EGR or something, i'll try to change the pump and injectors beacus my pump is from nissan micra/march k11
thanks again for the tip dude
also i don't want to spam may be there's other place can someone recommend cam sprocket settings for S3 cams i mean retard or advance on EX/IN cams
just wondering if anyone had an idea i just baught my G/F a b13 with jdm sr20
Megan header, 2 1/4 full exhaust, exedy clutch and 9lb flywheel,CAI ........... anyone know a round about WHP it should lay down ????
N15 Nissan Pulsar. 108.3kw = 145.2hp atw. Keep in mind that this was a rolling road dyno, and dynos here in Australia read a little lower than the US variants.
Mods are: Pod filter, standard intake piping/resonator, JWT C2 cams, Supertech dual valve springs, Ti retainers, X-force extractors, 2 1/4 mandrel exhaust, hi flow cat, offset muffler, Fidanza flywheel and a PLMS daughterboard (aussie equivalent to Calum basic board)
Today I went over to Hi Tech Motorsport for a Dyno test & rolling road tune i.e. fuel pressure and ignition timing optimised. Yes the gear he uses is old, however my engine is old too.
Been here a total of 4 time now and each time I could not fault the readings. Then with the NPOC (G20 chassis) chaps DE’s with I/E/H made around 135 – 140whp the same over the UK for same tuned SR20DE’s
Engine mod list
MIJ 2.25'' stainless steel mandrel cat back
Edge Racing 2.5’' resonator decat
Tomei Poncams 260' at 0'0
ASP 4-2-1 header with 3’ downpipe
2 piece UR lightweight pulleys (ran out of time to fit the PAS)
FSE fpr set to 4bar
PiperX panel filter with cold air feed
2.5’ induction hard pipe kit
Magnecor KV85 HT leads
NGK Iridium spark plugs
Ignition timing at 19*
XTD prolite flywheel & stage 2 clutch
163whp @ 6400rpm & 180lb ft @ 5400rpm
not quite the 200bhp mark, its 196bhp @ 6400rpm with ignition timing set to 19* and fueling set to 4bar. It was 192bhp @ 17* ignition advance, however at 19 there gains everywhere.
Outlaw Engineering Thermoblock Spacer
Timing to 19*
all 4 UR pulleys
2.5" SSAC header
2.5" mandrel bent exhaust
WRX STi muffler
ghetto CAI mod
K&N Drop in Air Filter
JWT S3s
JWT ECU Flash for S3s
JWT motor mounts
I would expect that set up to get about 155 whp on a good day from what I've read.
If I went with JWT S4's and a JWT ECU tuned for S4's, what would I exect to get? 165 whp? and how would the torque curve look? I'm tired of searching!!
1991 |black | SE-R
all season tires | hypercoil gen ii springs | shortened koni struts | ST front sway bar | (WTB progress rear sway bar) | octotat 3 point RSTB | octotat 2 point FSTB | ad22vf calipers | carbotech pads | blowd up DE with VE being installed | hotshot cai | ssac header | 2.5" mandrel bent exhaust | wrx STi muffler | UR pullies | jwt motor mounts | B&M short shifter |
a Macidcrook>> i see you had your Dyno done in Murrieta Ca.!!!! Nice thats my home town.. whats up bro. i'm new to the Sr20 scene looking for local SER'ers for parts and advice.
hi wink yes my shop used to be in murrieta. i live there and alot of other b13 guys do too. we arent really on this forum much so you should head of to the dash and introduce yourself on my temecula thread. alot of good guys are on that thread so you wont get any false info like most forums. feel free to ask away. heres the link go to the temecula meet thread its usually at the top
IMHO people who are not willing to spend time doing a little bit of reading and reserch are not of the proper mindset to build motors in the first place. I am not talking about you specificaly but just people in general.
1998 B14 SE-R
1996 SR20 Junkyard engine with 60K miles
OBX header
Hotshot downpipe
UR four pulley set
Short ram intake
2.25 inch Dump pipe exhaust
Stock cams
Stock 1995-96 G20 ECU
19-20* timing advance
100 octane gas
No CAT
No emissions
No muffler
The first two runs are in 4th gear and the last run is in 3rd gear.
1998 SE-R, 2008, 2009, & 2010 ITA Champion, SoPac Region
2002 Toyota Tundra V8 SR5, tow truck, 207 hp, 271 lb-ft
2010 VW Golf TDI
2007 Silverstone Honda S2000
