sr20de 4 throttle - SR20 Forum
post #1 of 23 (permalink) Old 10-03-2007, 11:38 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
sr20de 4 throttle
hi all,i got a sr20de lowport with highport inlet cam and quad throttles off a gtir adapted onto it,pistons are standard 10:1 flat tops
does anyone know if the head can be machined to raise the compression,and if so how much can be removed without running into problems?
im hoping to get at least 11:1?
or would i be better off to change over to sr16ve or vg30 pistons to raise the compression?
thanks very much in advance.
redbike is offline
post #2 of 23 (permalink) Old 10-04-2007, 12:12 AM
No Tune = No Life
Quoted: 0 Post(s)
Feedback Score: 7 reviews
P&P head + SR16 pistons + GTIR itb's + Calum Chipped ECU = All Motor Nice set-up
alfsentra is offline
post #3 of 23 (permalink) Old 10-04-2007, 12:13 AM
The Fast One
Quoted: 0 Post(s)
Feedback Score: 12 reviews
just use sr16ve pistons it real easy.
http://www.sr20forum.com/members-rides/124356-gti-r-swap-done.html
Go figure the only sr20 in afghanistan is the x-trail sr20vet
se200 is offline
post #4 of 23 (permalink) Old 10-04-2007, 01:54 AM
Cuddles with his SR20s
Quoted: 0 Post(s)
sr16 pistons will give you close to 12:1. but you deffinitly need to port and polish your head if you want to make any good power. stock srde heads dont flow well at all.
Originally Posted by choaderboy2 View Post
IMHO people who are not willing to spend time doing a little bit of reading and reserch are not of the proper mindset to build motors in the first place. I am not talking about you specificaly but just people in general.
Reading is the key to knowlege.
macidcrook is offline
post #5 of 23 (permalink) Old 10-04-2007, 02:12 AM
Weekend Warrior
Quoted: 0 Post(s)
Feedback Score: 60 reviews
^P&P is mainly good for TURBO though right? How many HP's would a P&P do on a BONE stock SR20DE motor with NO OTHER MODS just the P&P?
Bend But Don't Break
MR-4Door-SR20DET is offline
post #6 of 23 (permalink) Old 10-04-2007, 06:18 AM
Ser Charles
zerogravity's Avatar
Quoted: 0 Post(s)
Feedback Score: 5 reviews
Not much. You want a port job with cams,headers,exhaust, and intake to make them all work right. Porting is not mainly for turbo because porting for turbos are way different then porting for NA.
www.cfxpaintworks.com
"There is one thing man should truly fear...it is the INDIFFERENCE of good men..."
My Set Up:
Motec Exhaust*Walbro Header*MSD Rims*Jim Wolf Custom Paintjob*Injen Tires*Mugen Glove Compartment*MazdaSpeed Bridgeport*Edlebrock Exhaust Bearings*Calum Power Mirrors.
Damn My Sentra Hauls!!! 93 Whp of PAIN!!!
zerogravity is offline
post #7 of 23 (permalink) Old 10-04-2007, 03:48 PM
Quoted: 0 Post(s)
The head can have 1mm removed, Dave Bull and others have done it, but you will need cam gears and an N1 chain tensioner.
Mike
UK-SRi is offline
post #8 of 23 (permalink) Old 10-04-2007, 04:16 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Mike
cool,this is the prefered option,what sort of c/r can i expect by taking 1mm off the head?
i shoul have listed the other mods i guess
link ecu
custom 4into1 headers
thanks for the input thus far
redbike is offline
post #9 of 23 (permalink) Old 10-04-2007, 04:19 PM
'The Sleeper'
Quoted: 0 Post(s)
Mike
I had 1.2mm removed from the head Mike, and just used the stock RR chain tensioner.
Cheers
Dave
N15 with a built SR20DE+T.
GT30R hybrid at 22 PSI...403 WHP (dyno' in 5th gear)
Bull GTi is offline
post #10 of 23 (permalink) Old 10-04-2007, 05:48 PM
Weekend Warrior
Quoted: 0 Post(s)
^Three angle valve jobs are for turbo.........Then what kind of P&P would be best for all motor? I ask bc you say that the air flow is different between the two. Which I agree, but wouldn't that be because of the HIGH FLOW work action of the turbo? The aire would still travel the same through the INTAKE MANIFOLD, just at a HIGHER SPEED........
post #11 of 23 (permalink) Old 10-04-2007, 06:57 PM
Quoted: 0 Post(s)
The air is at a higher pressure in the turbo inlet, it doesnt rely so much on the piston vacuum, so you can hog the ports out bigger for a higher flow and not care quite so much about the velocity.
Mike
UK-SRi is offline
post #12 of 23 (permalink) Old 10-04-2007, 07:55 PM
Ser Charles
Quoted: 0 Post(s)
you want a 3 angle vallvejob regardless if it were turbo or na. Like what mike said...with air being pushed in insteal of sucked in, turbo porting needs more work on teh Exhaust side. WHen porting for NA, you want to get as much Velocity as you can...its not just a matter of making the ports bigger.
Ill be posting pics of my head tomarrow when i goto DPR and get slowcharts as well. Ill further explain the differences of teh two ports when i get pix in.
My Set Up:
post #13 of 23 (permalink) Old 10-05-2007, 03:15 AM
Weekend Warrior
Quoted: 0 Post(s)
^Thanks for the reply...........can't wait to see the pics.
post #14 of 23 (permalink) Old 10-07-2007, 08:57 PM
Quoted: 0 Post(s)
send pics 2 check out the workmemship and looking 2 do the same in theny area
2fastsr20 is offline
post #15 of 23 (permalink) Old 10-07-2007, 10:43 PM
www.wheelsjamaica.com
Quoted: 0 Post(s)
Feedback Score: 3 reviews
yes zerogravity post pic.z
venom2727 is offline
post #16 of 23 (permalink) Old 10-07-2007, 10:44 PM
Ser Charles
Quoted: 0 Post(s)
have not gotten a chance to stop by, probably tomarrow or tuesday for sure. I been running around doing other things.
My Set Up:
post #17 of 23 (permalink) Old 11-06-2007, 03:53 PM
Ser Charles
Quoted: 0 Post(s)
ok,,,the cam journals have been polished, head has been deburred, now all im waiting on is the port job and valve job.
My Set Up:
post #18 of 23 (permalink) Old 11-06-2007, 04:50 PM
Quoted: 0 Post(s)
link ecu
By my measurements, 1mm removed from the head will reduce the chamber volume by 5.36cc, you need to do YOUR sums for the gasket, final deck height and any other changes you make factored in to give you your final CR.
BUT with a bone stock engine, flat-top piston, it will raise the cr from 10:1 to just over 11:1.
Mike
UK-SRi is offline
post #19 of 23 (permalink) Old 12-03-2007, 11:28 PM
Im all about the 4x4
Quoted: 0 Post(s)
Feedback Score: 35 reviews
the gti-r itb does not give any power gain on a NA motor, it just gave throttle responce, when i went from the jdm intake manfold to the gti-r all i got was alot more crisp throttle responce but my car was slower
Im Looking for a P10 G20T 5spd or a NX2000 5spd
specalk is offline
post #20 of 23 (permalink) Old 12-21-2007, 04:46 AM
Ser Charles
Quoted: 0 Post(s)
Do you have any dyno numbers to prove this? Reason why im asking, i drove my buddy's Ve which is 190whp and my car is a De with 154whp. Mine "feels" faster but dyno says other wise. I would think the GTiR ITB's would give some hp gain...but with no dyno's..it is hard to make that assumption.
My Set Up:
  SR20 Forum > Main Forums > All Motor
User Tag List
