Old 02-21-2008, 01:27 AM   #21 (permalink)
2sNoAR
subscribed! keep us posted. interested in doing a similar build.
2sNoAR is offline   Reply With Quote
Old 02-21-2008, 02:13 PM   #22 (permalink)
Nismo87SE
I too have cam gears on my C2s which are similar to your BC 3s. I've tried +5 int -5 exh but I lost top end power and gained midrange. How is your idle, mine was really choppy and I had a lot of hesitation and stumbling below 2000rpm with my cam gears set to +5, -5. Eventually I set them to -4, +4 and all hesitation and stumble is gone, although the car is weaker down low and midrange. Top end seems to be fine.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline   Reply With Quote
Old 02-21-2008, 10:48 PM   #23 (permalink)
mercado se-r
nice i have 2.5 in int and exh with stock cams and you feel it that it works
mercado se-r is offline   Reply With Quote
Old 02-21-2008, 10:54 PM   #24 (permalink)
robchaos19
Robusto
Trader Rating: 74 (100%)
Mine seems to be pretty nice all around. I am probably just keeping the gears where they are. I got my SAFC wiring that up tomorrow.
who the fu*k just sits there and highlights text at random?
robchaos19 is offline   Reply With Quote
Old 03-05-2008, 08:23 AM   #25 (permalink)
seguroski
any dyno updates?
98' SE-R(DD) [I/ H/ E + S3's 17*timing]
F/S: G20 'non' LSD tranny $275 shipped
seguroski is online now   Reply With Quote
Old 03-05-2008, 09:26 PM   #26 (permalink)
robchaos19
Robusto
181.2 HP and 147.6 ft/lb tq when I did my SAFC, however I am getting alittle fed up with the ability of the dyno operators where I have been going. I am hoping to get in touch with fellow forum member nissasin to see if I can acquire some dyno and tune time at his shop (agile automotive) to use the Dynopack to tune my SAFC. I think it was done improperly at the place I was at last.
Old 03-05-2008, 09:45 PM   #27 (permalink)
seguroski
great numbers men! I love this build I've been following progress like TV series show . Did the dyno problem not reading above7k problem got fix???
Old 03-05-2008, 10:02 PM   #28 (permalink)
robchaos19
Robusto
nope. The problem is their POS dynojet RPM lead keeps cutting in and out, so the dyno cuts off, the only way I got my peak HP and tq numbers was by viewing the dyno chart by speed, not RPM.
Old 03-07-2008, 11:17 AM   #29 (permalink)
Rob E
Dyno-Jet seems to have this problem quite a lot. I have used one to dyno cars that run with rev-limits between 6800 and 9800. The lower RPM cars seem to work fine. When you get to the higher RPM cars it seems that the ignition trigger lead is unreliable in half of the runs.
I guess that is what we get for using a Dyno that was basically designed around a Harley. (read their story)
Good luck finding a better dyno to run on. Keep posting as we all are reading your progress as it goes along.
Rob E is offline   Reply With Quote
Old 03-07-2008, 12:07 PM   #30 (permalink)
WAFFLES
Redneck Diesel Mechanic
have you checked the piston-to-valve clearance yet?
Black 91 SER
Camoflage Metallic 05 Scion xB
WAFFLES is offline   Reply With Quote
Old 03-08-2008, 01:03 AM   #31 (permalink)
STRATTON
i love b13's !
Trader Rating: 20 (100%)
rob 181whp 147 wtq with the ssac 2.5 and the sh*ttly tuned safc ??
if so thats good numbers, with the safc tuned correctly you will most likely be able to pull a tad more out of it.
stratton.
im back.......
Old 03-08-2008, 01:36 AM   #32 (permalink)
robchaos19
Robusto
Thats what I am hoping. If the rain can hold off tomorrow, I am gonna try and get to the track
Old 03-08-2008, 07:16 PM   #33 (permalink)
coryb13ser
the proof wizard
Trader Rating: 26 (100%)
i dont get why you guys are having all this trouble with the dyno, ive run up to 9.2k and never any issues with the dynos
12sec NA
Old 03-08-2008, 09:54 PM   #34 (permalink)
robchaos19
Robusto
What kind of dyno are you using? The shop I have been taking it to hooks me up with a good price for the time, but they have a old ass dyno with crappy equipment. What is there to not get about why they are having such a hard time???? It is simple. The lead that goes to the spark plug to sense RPM keeps cutting out for whatever reason. That is not hard to get.
I am hopefully going to be able to get a good price at agile automotive which is about 50 minutes away from me, and they use a dynopack dyno and much newer equipment.
Old 03-12-2008, 04:39 PM   #35 (permalink)
671ser
awesome build, any plans on running it at the drag strip?
671ser is offline   Reply With Quote
Old 03-13-2008, 05:00 AM   #36 (permalink)
2sNoAR
^x2 i'd like to see the times on this beast. nice build! what made you choose the bc's instead of the jwt s4's? im still stuck at that pitchfork road...
Old 03-13-2008, 07:15 AM   #37 (permalink)
robchaos19
Robusto
the fact that the BC stage 3s are $250 and the JWTs are $600 for the comparable c2s. weather permitting, I will be at the track saturday.
Old 03-16-2008, 01:05 AM   #38 (permalink)
B15sentraDE
finally got a classic
definatly post the time slips
b13 with high compression and S4's
soon to be on squeeze!
B15sentraDE is offline   Reply With Quote
Old 03-16-2008, 01:57 AM   #39 (permalink)
erick212
The more sensitive me
erick212's Avatar
I just wanted to bring up an old thread to let people know what you can do even without pistons on old tech. I was involed with the first # but, when Jay went out of biz we made a little more power and added a bottle. This car was nasty. tuning is a BIG factor.
http://www.sr20forum.com/all-motor/8...ecord-s5s.html
06 Frontier - tow truck
92 Sentra se-r - project N20 ---- last in line
95 200sx se-r - the low budget booster... Running
92 Sentra se-r - no autoX... just boosting this one too
low post count=working on cars more than computers
SR20deep Ct.
www.savagefighter.com
erick212 is offline   Reply With Quote
Old 05-01-2008, 11:27 PM   #40 (permalink)
mercado se-r
sorry to ask but wirh st2 bcrower what would be the best cam gears timing 5+ / -5
