Old 03-25-2008, 12:28 AM   #21 (permalink)
classicaddict
this foreum= FAIL
Originally Posted by STRATTON View Post
heres what i would change (im also assuming this is a de motor your building)
12.1 wiseco pistons
stock rods
new stock bearings
new stock head bolts
new stock head gasket
bc stage 3 cams and s&r
100 shot direct port
jwt ecu with a nitrious tune with the switch (na/nitrious)
ssac 2.5 header
3' exhaust
the car will be bad ass all motor and tuned correctly will handle the nitrious with out a hick up even with the stock internals.
stratton.
i wouldnt touch an oem de gasket. the composite is garbage. the VE head gasket is the hot ticket.
THIS FORUM HAS BEEN AROUND SINCE 2000........TRUST ME WHEN I SAY YOUR QUESTION HAS ALREADY BEEN ASKED. SEARCH BEFORE YOU POST....PLEASE
please read this link to expand on above.
Old 03-25-2008, 12:38 AM   #22 (permalink)
classicaddict
this foreum= FAIL
to everyone posting in this thread who is new i request you do a small search in the all motor section on thread that have been started in the past couple months. mainly the ones started by "robchaos19"
NA builds are the new hot ticket. they cost about the same as a turbo setup with an untouched engine however i feel they are better and here is why.
building a high comp engine is (in a nut shell) completely rebuilding an engine........making it brand new, resealing it, while making it much more efficient in the process. your not slapping a 100+ HP maker on an engine leaking everything known to man. also your not adding a bunch of crap.
Old 03-25-2008, 01:33 AM   #23 (permalink)
rock
amen to n/a builds!!!!
not as fast as turbo setups but very reliable...
its good to know bc cams are good ive always heard that jwt cams are best...
but ive been searching the forum with info regarding the c series cams but not too much is out there......i understand that these are mostly competition and do require there own set of springs and retainers...how do these add up as far as reliability and rev.....does anyone use stand alone computers like haltech?
ive been searching the forum for about 6days now and trying to soak everything
up....man its alot ......i want to build an n/a motor that can rev high and be reliable.....
ive read robchaos' thread....how reliable is your motor,is it a daily driver....what rev do you make power to?
thanks for all the info guys im getting ready to start the build soon
rock is offline   Reply With Quote
Old 03-25-2008, 11:09 AM   #24 (permalink)
MR-4Door-SR20DE
The community left.......
Trader Rating: 28 (100%)
Originally Posted by classicaddict View Post
i have heard "rumors" that ARP will be updateing their stud design for our cars. however the part number will be the same as well as packaging..........so there wont be any way to tell.
not to thread jack, but what will your power goals be? anything under 350 estimated HP SHOULD be ok with OEM bolts but dont quote me on that.
^That is sh*ity.........I guess I will give them a call when the time comes.
very true, the 16ve pistons give what a 11:5:1 compression in a de ? they are cheap and can be purchased threw greg vogel.
head work would not be a must, but would be a major plus. it would be as reliable as a stock motor with stock internals .
brian crower stage 3 cams with a spring and retainer kit is good to like 8200-8500 from what ive heard, they wont make power that high though.
absolutely not, usdm or jdm stock compression (9:5:1) is great for turbo you do not want to run high compression pistons in a turbo application.
stratton.
^I think it's 11:8:1
Originally Posted by EPSentra View Post
But if you're doing a driver + race the 11-12:1 is real high for pump gas.
^Not at all.............It's honda boys running 93 pump on compression as high as 13:
BEND BUT DON'T BREAK
Where is the community?
MR-4Door-SR20DE is offline   Reply With Quote
Old 03-25-2008, 09:58 PM   #25 (permalink)
Brandonsr20
hey sry guys i just got back from virginia but i read the post i already have got all my parts minus the nitrous kit so considering i could have saved alot of money on parts by buying ve pistons and using stock rods i really just wanted to build a completly bullet proof engine from the ground up of course a good tune is always needed for this to happen we all know u can have the best parts but without a good tune u best kiss ur expensive parts good bye!
Brandonsr20 is online now   Reply With Quote
Old 03-25-2008, 10:00 PM   #26 (permalink)
Brandonsr20
im gonna start puting this thing together this weekend hopefully have it tuned and runnin the way i want it in about a month. no hurry im takin my time on this one i will keep u guys posted on the build thanks for the input
Old 03-25-2008, 10:18 PM   #27 (permalink)
Rob_96
2001 B15Ve
sweet i would like to see some pics and maybe a vid of the build... good luck
Rob_96 is offline   Reply With Quote
Old 03-25-2008, 10:30 PM   #28 (permalink)
classicaddict
this foreum= FAIL
im really not a fan of forged internals for street cars to be honest. forged parts have different heat expansion properties and tend to slap around for the first few minutes and that really bothers me. the sr16 pistons are a goos 11.5:1 compression or so, and are prepped with swain like coatings on the dome and skirts. if possible i would highly recommend you return the after market pistons and slap a set of ve's in there.
Old 03-26-2008, 02:29 PM   #29 (permalink)
Brandonsr20
were is the best place to find a set of ve pistons?
Old 03-26-2008, 03:43 PM   #30 (permalink)
classicaddict
this foreum= FAIL
www.gspec.com
Old 04-02-2008, 08:22 PM   #31 (permalink)
Dman
Green s13
hey guys im new to this forum stuff
i just threw a s14 engine/box in my s13 replacing the ca18 auto
and puttin in headers/full 2.5 exhaust and CAI
i want to go all motor and shorten the diff ratios
what do u recomend?
Dman is offline   Reply With Quote
Old 04-02-2008, 08:25 PM   #32 (permalink)
EPSentra
First thing is to start your own thread on it. The original poster to this thread has a topic he wants discussed. General courtesy includes starting your own topic.
EPSentra is offline   Reply With Quote
Old 04-02-2008, 08:28 PM   #33 (permalink)
Dman
Green s13
cheers thanks for the advice
Old 04-02-2008, 08:36 PM   #34 (permalink)
Dman
Green s13
excuse my interuption but may ask how do i post a new topic?
Old 04-02-2008, 09:16 PM   #35 (permalink)
robchaos19
Robusto
Trader Rating: 74 (100%)
who the fu*k just sits there and highlights text at random?
robchaos19 is offline   Reply With Quote
Old 04-11-2008, 12:16 AM   #36 (permalink)
topdog781
SE-ROLGIST
topdog781's Avatar
Originally Posted by robchaos19 View Post
That's real clean , time to clean out those pm's ha ha.
"I am the representative for the people"
topdog781 is offline   Reply With Quote
Old 04-28-2008, 12:09 PM   #37 (permalink)
Silver Surfer
This sounds like a good build with the SR16 pistons, but I am not sure about the juice on the motor? I would rather just keep it N/A and go with the JWT cams. The guy who designed them is one of the top cam designers in the world, and even has his own nick name: The Cam genius! HAHAHAH!
Silver Surfer is offline   Reply With Quote
Old 04-29-2008, 01:55 AM   #38 (permalink)
Sabre 200 Gxi
Spot on. If you wanna run the happy juice then a metal gasket is the way to go.
Chrome rims suck b@lls
Sabre 200 Gxi is offline   Reply With Quote
