Old 05-01-2008, 03:25 PM   #1 (permalink)
blacksr20p10
........p10........
Hydrolic vs. Solid lifters
Ok, my p10 has the infamous ticking sound which I think is coming from the lifters not being bleed when my head was rebuilt awhile ago and I have a few questions. I don't know a whole lot about the engine internals and I've done alot of searching on this problem as well. What are the advantages of solid lifters over the stock hydrolic lifters and will it help me if my car is pretty much stock. I need to bleed my lifters and want to know if its worth it to upgrade?
blacksr20p10 is offline   Reply With Quote
Old 05-24-2008, 09:48 AM   #2 (permalink)
sssanctum
Autech
Hydraulic lifters have "give" in them so to speak to make sure contact is maintained on the rocker to shims durating the cam rotation cycle.
Solid lifters have an advantage at high RPM simply because they are solid - there is a constant and consistent strength contract during the whole rpm range. The reason being motors like the GTIR are solid is that hydraulic lifters tend to get pump up in high rpm - and loose a percentage of their ability to maintain firm contact between the rocker and shims - leading to thrown rockers etc.
The downside to having solid rocker?
1)Clearances have to be precise - otherwise their noisy as buggery and arent as effective. Be prepared to get a set of feeler guages and checking the shims tolerances every 10-20,000km's.
2) Your camshaft choices becomes limited as you need a different grind on different sticks.
All Motor Autech SR20DE - 160whp - stock
sssanctum is offline   Reply With Quote
