scc cam comparo link (please make this a sticky!) - Page 2 - SR20 Forum
Old 12-18-2002, 12:53 AM   #21 (permalink)
it's an se-l..not an se-R
REDSENTRASE-L is offline   Reply With Quote
Old 12-18-2002, 12:54 AM   #22 (permalink)
Old 01-30-2003, 11:51 PM   #23 (permalink)
those dyno results are wierd, i dynoed in at 138.2 hp and 132.5 tq with just a intake cam and nothing else,here in florida...
Second place is the first loser
Mr_VVL is offline   Reply With Quote
Old 06-15-2003, 05:26 PM   #24 (permalink)
SR20 Cashew
at the wheels?
'99 SE-L, '91 intake cam, '96 G20 ECU, Hotshot CAI, Pacesetter Header.
SchmottySE-99 is offline   Reply With Quote
Old 06-15-2003, 05:39 PM   #25 (permalink)
Feedback Score: 12 reviews
THose numbers are about right for that year car.
Steve
06 G35 6MT
Old 06-24-2003, 11:36 PM   #26 (permalink)
ok i read most of this sticky and i was really looking for is this what cam is good to add to my sr20de (95 200sx se-r) im not all good w.the cam mods. so i see peeps posting s3s or s4s. i was think about the jwt cams.What other cams are good like the jwt .is jun good to.Also i was woundering does anyone have a 95-99 200sx se-r w.either cams and what do u think about it thanks for the help and replys
200sx SE-R 95': Hotshot hearders, B&M short shifter,uped the timeing 17,hi-flow cat,full exhuast system,H&R springs cool air intake.
Hoping to get my sr20det.......
hotshot SE-R is offline   Reply With Quote
Old 06-25-2003, 06:24 PM   #27 (permalink)
Simian Rex
The killer with non-JWT cams is that nobody really knows how good they are. For the money, and the proven results, and the quality of product, nothing beats JWT. S3 for gains all around, S4s for more HP with a slight loss in low-end torque. Period. If you can afford the springs and retainers, JWT C-series cams are even better.
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 07-06-2003, 06:01 PM   #28 (permalink)
The Super Mechanic
supercowboy's Avatar
Feedback Score: 9 reviews
Jun cams
Jun cams are real good but there is no support for them. They come with no type of specs to degree the cams. I ran them with the stock degree numbers. I recently put 185 hp and 145 torque with the JUN cams. the jwt is very conservative. I like the tomei stuff better. they give you specs to degree your camshafts properly. How many people have degreed there cams on an sr20. I bet not to many. Regarding the the scc article if you notice the smaller Tomei cams put just as good numbers as the s4. The mid range power of the the car certainly is better than the JWT, but everybody is looking for peak numbers. Remember its not how fast your going its how fast you get there!!!!
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
DO YOU KNOW WHO I AM!!! I THOUGHT SO!!!!
supercowboy is offline   Reply With Quote
Old 07-07-2003, 06:29 PM   #29 (permalink)
Simian Rex
Actually, a pretty good number of people are running around with advanced S4s, which lose practically no power below 4000 RPM to S3s, with massive midrange punch and upper HP that still beats S3s by a significant margin. The Tomei cams make me really nervous; I don't like the idea of being able to flake material off of the cam shaft (not lobe, but shaft) with my fingernail.
Old 07-08-2003, 12:38 AM   #30 (permalink)
The Super Mechanic
advancing the cams should lose bottom end torque and increase rpm, retarding the cams will gain low end power. if you look at the graph the s4 cams will pick up very high in the rpm band. Almost when it is time to shift. I would rather have a pull in a 2500 or 3000 rpm band. cars feel more powerful that way. also the comparison of the cams in that article are horrible who would measure power after it falls off (note the down curve on those graphs.) I have never seen any of there cams flake like that. If they did they would exchange them at no cost im sure. they have a real good customer service. there.
Old 07-08-2003, 11:01 AM   #31 (permalink)
Simian Rex
I really, really, really need to read that entire article again. I read it when it was first published, but being the owner of a '95 Saturn and a '94 Tercel at the time, the SR20 stuff only marginally interested me, and I threw out that issue. Does anybody still have the complete article[s] on-hand?
Old 07-14-2003, 10:31 AM   #32 (permalink)
ok guys a question about,with type of head they use pre 94 or post, i know that the stock 91vs 98 was on 91 head, but i dont know in what head were test the S3 and S4?
primerap11 is offline   Reply With Quote
Old 07-15-2003, 10:07 PM   #33 (permalink)
Simian Rex
All tests in that article were on the same head, in the same car, with the same configuration. That's what made the article so good; all factors were equal. The only thing that might be a bad thing was that they didn't show a low-port cam in a low-port head. BFD.
Old 07-16-2003, 01:54 AM   #34 (permalink)
when my car was all motor with advanced timing i made 145 whp with intake cam....
Old 09-19-2003, 12:09 AM   #35 (permalink)
what the f@$% a stock G20 motor only put out 114 HP?? WHat the hell is going on. Its Rated 140 at the flywheel. Is it possible to lose 26 hp???
Old 09-19-2003, 07:04 AM   #36 (permalink)
SE-R GREEK
Feedback Score: 8 reviews
26 of 140 is close to 15%.
Yes, it is possible and almost all engine-tranny-drivetrains in production loose that much...
Chris
Old 10-22-2003, 06:22 PM   #37 (permalink)
Does anybody have a link to the entire scc cam shoot out dynos? I saw it before but I don't have the link anymore.
99SE-L is offline   Reply With Quote
Old 01-08-2004, 06:09 AM   #38 (permalink)
GT2835R
Cant wait till i get my S4s installed.
Rey Uy
99 SE-Limited
Old 03-19-2004, 09:49 AM   #39 (permalink)
the original 4-door SR20
Feedback Score: 6 reviews
Re: scc cam comparo link (please make this a sticky!)
You know what I find weird? The gain from the stillen intake. I always here that the JWT pop/still pop WAI only give you 1-2 hp. But it shows a 6.9hp gain. Not to bad.
96 G20 Turbo:Sold
93 NX2000: SOLD
91 SE-R: SOLD
99 G20T my DD
93 Mustang GT, built not just for straight lines....
jamse-r is offline   Reply With Quote
Old 04-01-2004, 11:27 PM   #40 (permalink)
P10 Geek
Thread from the dead!
Actually, those numbers are complete BS! Stillen products always claim to produce unproven HP gains. And to be honest, I do not believe that SCC actually provided any support for those dyno runs. They just posted what was provided to them.
As for the cam shoot-out, I know those numbers are a bit more accurate.
Brandon
'02 Maxima SE 6MT
'96 G20 (SOLD)
