what has anybody done to get rid of wheel hop? I have solid mounts,es bush,kyb agx 4-ways.
SR20 1320 Racing
SR20DEN Up N runnin 1.64 60ft 11.8@119 Direct progressive 50SHOT 1ST,2ND-100SHOT 3RD,4TH
ALLNITROUSENTRA
and a little bit of compression
Be an innovator not a replicator My Nitrous Monster All the videos of my car just scroll down!!!!!!!!!!
well thats another issue when i was runnin drag radials if i set them at 17 psi i would lose 4 tenths (prob ***** i could have launched harder) but w/ street tires i run them at 25-30psi
I just recently had my front bushings changed and i would defniately recommend it to everyone else. I havent taken it to the tracks yet but just driving around on the streets you can definately tell that the car is a lot stiffer now. One of my control arm bushings were so worn out that you can shake the whole control arm back and forth, similar to a worn out wheel bearing but worse!
Stealin's G load brace works pretty well for wheel hop. I plan to also get some motor mounts and see if I can get rid of some more.
I was running almost 2 degrees of negative camber and I had alot of wheel hop at the track. I found in my experience that when I ran closer to zero negative camber and zero for toe, I had less wheel hop or no wheel hop at all.
If you can't afford JWT's hollow them out. Then pour your own. That's what it took for me. The right tires at the right pressure matter too.
I haven't ahd the control arm bushings, but Imagine they would help imensely as well.
Originally posted by ALLMOTORSENTRA what has anybody done to get rid of wheel hop? I have solid mounts,es bush,kyb agx 4-ways.
i had the stock mounts filled with solid plastic but apon inspection i found the bolt sleeve has broken off of most of the mounts and reamed out the hole.Good thing i work for nissan *** i can get the nismo mounts real cheap(they r really jwt mounts) the nismo catalog even sells s3's
