what will these pistons do to a SR20DE - SR20 Forum
Old 01-09-2012, 11:50 PM   #1 (permalink)
if I install these pistons:
http://www.sr20forum.com/naturally-a...ve-hybrid.html
in a 1991 SR20de (NX2000) engine what will the compression ratio be? I am looking for pistons around the 10 to 11:1 area.
lophilip is offline   Reply With Quote
Old 01-13-2012, 02:35 AM   #2 (permalink)
If you are going to run a higher compression ratio then just get brand new pistons from Gspec performance. Get the N1 pistons with sr20ve rings. This would bring the comp ratio up to around 11:1 and you would not have to run race gas to not ping. Pump gas like super unleaded would be great and you will not have to worry about back pressure with stock exhaust manifolds and you can easily run these much safer than with sr16s. This would be the way that I would go.
bootiesan is offline   Reply With Quote
Old 01-14-2012, 11:05 PM   #3 (permalink)
It looks like the machining modifications to these pistons will make them roughly equivalent to the N1 pistons.
Rob E is offline   Reply With Quote
