Old 10-13-2002, 02:44 AM   #1 (permalink)
Sr20kidD
Yes Dear.
Need help installing cams.
I wish to do it tomorrow.. but i know its a long shot
for anyof you guys to help me, however..
what are the tools and any suggestions or
recommendations and precautions that i should do to
have a successful install. TIA.
ps these are the GTIR cams i think. hehe.. but i know
i got them from a friend that used to have them on his
car. anywhoot.. anyhelp would be apreciated..
Sr20kidD is offline   Reply With Quote
Old 10-13-2002, 09:42 AM   #2 (permalink)
Matt
Pew Pew Pew
Matt's Avatar
Well they're not GTiR Cams. They won't work on regular SR20's. They utalize solid lifters.
Matt is offline   Reply With Quote
Old 10-13-2002, 10:14 AM   #3 (permalink)
SE-Rican
I would do soem research on the cams before you put them in. They may be stock cams. Like Matt mentioned they will not work for you Classic if they are GTIR cams
-Rob-
Get ready for a big SE-Rprise
Old 10-13-2002, 10:27 AM   #4 (permalink)
Matt
Pew Pew Pew
Matt's Avatar
I believe http://www.se-r.net has some pretty good write ups on how to install cams.
Old 10-13-2002, 10:45 AM   #5 (permalink)
ALLMOTORSENTRA
Drag se-r nut
The worst thing you can do is forget to wedge the chain tensioner.
1.Pull valve cover
2.rotate engine so timming marks r at (roughly) 10 and 2
3.Put paint on the corisponding link and zip tie the chain to the sprocket so it doesnt move
4.STICK A WEDGE DOWN THE FRONT OF THE MOTOR if you look down through the head into the front cover you will see(standing on pass. side)on your left the chain tensioner.Push the tensioner in with a wedge so you get slack in the chain.I use a big enough wedge so you can get it back out.Also i use wood *** there is less damage if you forget to remove it.
5.Now remove the sprockets
6.Remove the distributor(it only goes on one way)
7.Remove cam cap bolts fron inside out
8.Replace rocker arms if they r worn
9.Make sure all rocker arms and centering shims are in place
10.Install the new cams w assambly lube or ample amount of engine oil.
11.Reinstall spockets
12.Remove wood
13.Install dist.
14.valve cover
15.With new cams and rocker arms your supposed to run engine at 2500 for 10 min to seat cams but ive never done this.
16.Check timing
Sorry so vague w/no tools but i do this sh*t everyday and i know my tools location so i just grab and go.
I know their is prob some other good feedback some other poeple could offer!!!!!!!!!!
SR20 1320 Racing
SR20DEN Up N runnin 1.64 60ft 11.8@119 Direct progressive 50SHOT 1ST,2ND-100SHOT 3RD,4TH
ALLNITROUSENTRA
and a little bit of compression
Be an innovator not a replicator
My Nitrous Monster
All the videos of my car just scroll down!!!!!!!!!!
ALLMOTORSENTRA is offline   Reply With Quote
Old 10-13-2002, 10:47 AM   #6 (permalink)
ALLMOTORSENTRA
Drag se-r nut
I am currently running these cams in my usdm
Old 10-13-2002, 02:57 PM   #7 (permalink)
REDSENTRASE-L
it's an se-l..not an se-R
the wood thing just doesn't work for me. i couldn't get enough slack on the chain, so i just took out the tensioner. i do it the hard way. thats just me.
I'm irresistable to fat chicks!
DJ P-NOIZE
operation: iraqi freedom combat vet x 3
best time: 14.925@94 2.3 60ft at sacramento raceway without boost or juice
s4's/i/h/e/pullies/g20 ecu
REDSENTRASE-L is offline   Reply With Quote
Old 10-29-2002, 03:21 PM   #8 (permalink)
92_Sentra
I <3 MILFS
If I'm not mistaken only the exhaust cam will work from a GTi-R engine to a USDM SR20DE
James DeZarn
1991 Infinifi G20 SOLD
1992 Nissan Sentra SE-R
1993 Nissan NX2000
1995 Nissan 200SX SE-R SOLD
2005 Infiniti G35
92_Sentra is offline   Reply With Quote
Old 10-29-2002, 05:41 PM   #9 (permalink)
SmoothDaddyFig
NISSAN SOLDIER
e-mail me @ jonathan.figueroa@verizonwireless.com
I have a nice packet lined up for such an event.
E-mail me before 7pm if you can. Eastern time.
Jonathan
93 G20 "Im cruising tonight"
Old 10-29-2002, 05:59 PM   #10 (permalink)
CowboyDren
Simian Rex
I'm all but certain that they both work. Why would one cam work and the other not? Actually, some number of years ago, $teallin' sold a product that was for SR20DEs, which, as the legend goes, turned out to be straight-up GTi-R cams. They idle like sh*t in an N/A motor, but they fit, and run, and don't cost too much money. I'm not that ballsy, though. If I did the above swap, I'd want to get at least one adjustable cam sprocket and play with them on a dyno.
I love your bumper, by the way. Have you considered the Tsuru conversion, too? That'd be phat.
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 10-30-2002, 12:47 AM   #11 (permalink)
rednismo6
banned
i know if you go to sr20development they have a section the jwt has supplied them with how to install different cams, maybe that can help.....adam
rednismo6 is offline   Reply With Quote
Old 10-30-2002, 07:31 AM   #12 (permalink)
ALLMOTORSENTRA
Drag se-r nut
Like i said before i am running these cams in my n/a.I just put them in ***** i had them and i was bored and i ended up matching my best 1/4 time w/them so i left them in.
Old 11-06-2002, 09:09 PM   #13 (permalink)
92_Sentra
I <3 MILFS
Haha thanks man, I dont really want to do the Tsuru lights, I have Sunny lights, they work like the G20's. 2 bulbs in the headlight instead of one, and they are H4 They look very nice and are bright
