Old 12-16-2002, 12:04 PM   #1 (permalink)
SR20DET swap?!?!?!...need suggestions...
Hey I own a nissan 200sx SE-R (SR20DE) and my plan is to swap in a FWD SR20DET (possible?) on my own. Some people have told me that its not possible because my original engine is mounted horizontally and the DET is mounted vertically. Are they right?...or should it fit in?....with a mounting kit maybe?...idk
I have read about sr20det swaps into a 240sx but never a 200sx. Will a 200sx be much different?...Anyone done this swap or know of a place with dirrections on how to?
benigno200sx is offline   Reply With Quote
Old 12-16-2002, 12:19 PM   #2 (permalink)
There is a RWD SR20DET and a FWD SR20DET
FWD -
Pulsar GTi-R
BlueBird
You can use the FWD SR20DET in the 200SX, i was planning on doing the same swap.
SE-Romeo is offline   Reply With Quote
Old 12-16-2002, 12:25 PM   #3 (permalink)
Bad Banana
The swap is a snap. No custom work needed.
www.boostednx.nismo.org
Loe Lyf is offline   Reply With Quote
Old 12-16-2002, 03:08 PM   #4 (permalink)
do you know of any sites the explain the procedure on how to do the swap?
Old 12-16-2002, 05:50 PM   #5 (permalink)
another question to anyone whos knows baout this swap or as done it... what harness would i use for the DET in my 200sx?
....thanks
Old 12-16-2002, 06:13 PM   #6 (permalink)
Bad Banana
You use your existing 200sx harness.
Old 12-16-2002, 06:38 PM   #7 (permalink)
Simian Rex
Go to SE-R.net. Lots of information on DET swaps there. Also, you're in the wrong forum. This is "all motor," you need to be in "turbo."
-=|JP|=-
CowboyDren is offline   Reply With Quote
Old 12-16-2002, 06:40 PM   #8 (permalink)
G20style.com
You'd find more responces and posts in the turbo section. this is all motor NO tURBO section.
Ericdd is offline   Reply With Quote
Old 12-16-2002, 09:08 PM   #9 (permalink)
alright thanks guys
