Old 12-23-2002, 08:15 AM   #1 (permalink)
SE-Rican
New all motor dyno figures!
Well gang I wet to the dyno Saturday and I got some real good results.
Once again I have to give special thanks to Andreas Miko. He is the one to give credit to. Thanks Dre!! Also thanks to all my boys who have helped me aswell. You know who you all are.
All motor I put down 159.8 hp at 134.6 ft tq. I am .2 away from my 160 hp goal. With some minor tuning we will get it. I will try to post some dyno sheets up. If I can only find a scanner!!
-Rob-
Get ready for a big SE-Rprise
Old 12-23-2002, 08:57 AM   #2 (permalink)
scmser
What have you done recently? Anything?
Old 12-23-2002, 09:19 AM   #3 (permalink)
SR20loper
to get that extra 2 HP have you thought about those Grounding Wires that Turbo tested and on RX-7's got more then 11 WHP in some places just from ground wires being made from 100% Copper or something. I should be good for that 2 HP
SR20loper is offline   Reply With Quote
Old 12-23-2002, 09:25 AM   #4 (permalink)
SE-Rican
I have switched over from a PR CAI to a HS WAI/w POP charger and a JWT ECU with 100 shot program.
The ECU is programed for 370 cc injectors, and 100 shot program. Thats it. No cam program or pop charger program.
Old 12-23-2002, 10:22 AM   #5 (permalink)
Mr Sentra
Keeping It Real
Very very nice, Robert!!
Mr Sentra is offline   Reply With Quote
Old 12-23-2002, 10:45 AM   #6 (permalink)
Benito Malito
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 29 (100%)
Those are great numbers congrats. You may be losing that extra .2hp with the exhaust/header set up. As built as you have it n/a you may lose a bit accomodating that silly nitrous flow. I'm assuming you laid down both of these sweet #'s with the same exhaust sysetm.
Old 12-23-2002, 09:57 PM   #7 (permalink)
WickedSR20
Red line chaser
Nice numbers. I'm still wondering if the S3/S4 cam program is worth spending $100 on. At first I was going to do it to get better driveability on the street as it would stumble and stall if the car came from 4000 rpms and above down to idle, but it's not doing it anymore. Seeing your #'s makes me wanna keep the $$$ for other things. Impressive #'s indeed. Keep up the fine tuning.
WickedSR20 is offline   Reply With Quote
Old 12-24-2002, 11:02 AM   #8 (permalink)
1FastP11
^ He Covets a VET...
I think your gain in HP from the previous 157.5 are not due to the WAI but from the JWT ECU. Even if it doesn't have any specific program in it. it's still a optimized map. Plus, if you do 2 changes on the car at the same time an then dyno, you don't really know what gave the most power, or if one of the mods gave you any power at all. Having said that there's a posibility that if you would 've dyno with the PR CAI you could've past the 160 HP mark.
Just a thought
Claudio in Chile
2003 Nissan Primera GXE
The last of the P11s
Boost, NOS and displacement... Find a replacement for that!
1FastP11 is offline   Reply With Quote
Old 12-24-2002, 03:34 PM   #9 (permalink)
SE-Rican
Just a thought
1FastP11 you are correct. The car still needs some changes. We are trying to figure it out. Soon you will see 165whp from my car. We are going to put a custom (Andreas Miko) CAI on the car.
Old 12-24-2002, 04:33 PM   #10 (permalink)
sleeping 91ser
boosting
nice job rob, keep up the good work, I think with the Miko CAI and a few minor tweaks you will see your goals
sleeping 91ser is offline   Reply With Quote
Old 12-26-2002, 03:39 PM   #11 (permalink)
SE-Rican
Thanks for the compliments gang.
Old 12-26-2002, 03:49 PM   #12 (permalink)
Ericdd
G20style.com
put up a list of your other modifications.
Ericdd is offline   Reply With Quote
Old 12-26-2002, 07:29 PM   #13 (permalink)
SE-Rican
Here are my mods!
JDM SR20
JWT S4 cams
370cc injectors
Bored MAF
MSD SCI
MSD Blaster coil
H/S Header
H/S WAI/w POP Charger
UR pullies (2 set)
NISMO FPR
Walboro 255L
Custom 2.25 exhaust with GReddy muffler
NOS kit
Thats about it!
Old 12-26-2002, 09:36 PM   #14 (permalink)
Ericdd
G20style.com
MSD SCI MSD Blaster coil
I assume these are both for the NOS but did you see any difference N/A with them? What's your FP set at?
Old 12-27-2002, 06:10 AM   #15 (permalink)
SE-Rican
The main reason I did get them was because of the nitrous. NA I noticed that the revs seemed to be alot smoother. For NA I have my FP set at 38-39 psi. For nitrous runs I have it set at 41 psi
Old 12-27-2002, 04:45 PM   #16 (permalink)
Ericdd
G20style.com
Cool! I've been wondering about those things.
Old 12-31-2002, 12:19 PM   #17 (permalink)
Grip
Oh Fo Sho
Rob are you running 17deg. when you are off the bottle? If not bump it to 17 and you're 160 easy bro! If you've done this. try going to 19 and run 110 octane. Make sure they have good high flow fans and the weather is cooly cold!
Peace!!!
Grip is offline   Reply With Quote
Old 12-31-2002, 06:30 PM   #18 (permalink)
SE-Rican
Peace!!!
Ralph my timming was at 15 degrees. My car has always peformed better at stock timming.
Old 12-31-2002, 10:59 PM   #19 (permalink)
Grip
Oh Fo Sho
My bad you are correct I forgot you had the JWT ecu, it should always be at 15deg. sh*t thought I was on to something.
Old 01-12-2003, 05:38 PM   #20 (permalink)
KikoSanchez182
Master of the 5th speed
yes, have you tried some upgraded ground wires or just making your own??? i would be interested to see how much you gained with them.
KikoSanchez182 is offline   Reply With Quote
