So Mike K. for those of us looking to fab up our own intakes, is it safe to say that we should follow the HS design as close as possible using 3" piping and get a AFPR to tune AFR. Granted we plan on or are already using cams.
-Kenny
Is this an offtopic question?
Murfreesboro Sleeper Street Sweeper
91 SE-R--lots of mods SOLD
The Wolf
01 Jetta Wolfsburg 1.8t--APR 93/100 oct chip, TT 2.5" Downpipe, Forge 007, n75j, custom intake, votex springs
^^you would have to dyno to determine whether you need to boost your fuel pressure a bit. Mind you, it cant be done with an safc, you would need to actually dyno on a wide band O2.
Let me repeat that you need to test your car's A/R ratio using a real UEGO or Horiba wideband O2 sensor, not one of those autometer, haltech, MSD or other cheap meter that uses a stock type O2 sensor or the factory sensor.
You cant trust the dynojet wideband either, that sucker is way off. Any of the stick up the tail pipe units is suspect as well as I think there is a lot of dilution that far back on the exhaust.
AEM has a cheap wide band that uses a DMM as the readout. It works quite well and is cheap.
Why didn't you do any testing with the stillen CAI. I think it's one of the best crafted CAI, along with the AEM (not offered for my car). The place racing and hot shot, have no mounting brackts and have pretty cheap looking MAF adapters and filters. The only reason the stillen isn't more widely used is it cost more. The stillen uses the same size piping as the AEM as well.
Originally Posted by JustinP10
Does rotating the MAF so the sensor location changes in respect to the bend of the pipe affect anything?
Originally Posted by Storm88000
No, I don't think so. Basically you want the MAF rotated because the air flows through the intake better.
I have read posts that rotating the MAF 90 degrees from stock (hot wire on top) gives small gains in torque. It may be possible to slightly tweak your A/F ratio depending on MAF positioning along the intake tract AND its orientaion (hot wire up/down or right/left). What's best will depend on what you are trying to achieve and your intake--stock, not stock.
Air flow can differ in the area of the MAF, but more importantly, in the area of the hot wire within the MAF. The flow can differ in two ways. It can be turbulent or laminar (i.e., rougher or smoother, respectively), and it can also be slower or faster. Fast, laminar flow will result in the highest MAF voltage, and slow, turbulent flow, the lowest.
The factory fuel maps that a stock ECU uses will be based on readings from a factory intake and MAF positioning. A hypothetical situation: the stock MAF location/positoning may put the hot wire in an aera of slight turbulance and medium air speed as a result of the curves, bends, and surface irregularities of the intake tract and MAF body. The factory then programed the ECU with fuel maps based on MAF readings from that location.
If you were to rotate the MAF or somehow change its position so the hot wire was now located where the flow was more laminar (a.k.a. less turbulent) and or faster, but the overall air flow to the engine stays the same, this would result in a richer A/F mixture because the MAF is reading more flow, but actual intake air flow remains the same--only the MAF reading location changed, not anything that would affect the overall intake flow.
So how do you position the MAF to, in theory anyway, change A/F ratios? Air (or water) speed is faster on the outside of a curve, thus greater flow. So if you want the leanest possible mixture and there is a curve in the intake tract ahead of the MAF, rotate the MAF so the hot wire is on the inside of that bend. For rich, go to the outside. Trying to figure areas of turbulance or laminar flow is much more difficult, but if this procedure can have any noticable effects, which, according to the posts I mentioned at the beginning, is entirely possible, than this is a simple enough procedure to try some different positioning and see if it helps or hurts.
L8R
'84 VW Vanagon Westfalia (63 WHP, 5500# GVW)
'88 Honda RC31
'92 Nissan NX2000
'94 Nissan SE-R
'02 Klein Qunatum Race
'02 Santa Cruz Superlight
'02 Titus Switchblade
'XX Heavy Tool free-ride hardtail of unknown vintage
So what's the chances of anyone ever dynoing each of these intakes with the POP on the end of them?
Also, I have the PR CAI but at the begening of the thread where Mike K. describes how each is made, he described mine as the HS. The MAF is really close to the TB, and after the piping goes into the fender it turn's towards the front of the car. Well at least it used to, before I hacked it off to use the POP.
__________________ http://phatboyaudioonline.com/
1993 NX2000-5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, Brian Crower STG 3 cams, CP XTP 9.2:1 pistons, NX DP-100 shot, Prothane Mounts, ACT Xtreme/street disc, PR CAI with JWT POP, SSAC with 2.5" downpipe, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires with ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Xstatic Batcap, Axis maglites
My hotshot has the MAF closer to the TB and the filter tilts forward so the filter sort of tilts at a 30 degree angle. My PR has the MAF firther from the TB and the fitler points straight down.
The PR gives the most gains at 5500-6000 and my Hotshot peaks higher and has slightly less midrange. The Hotshot leans out the mixture and has higher MAF voltage and makes about 4 more peak hp than PR and 6 more than AEM with a custom ecu program.
I tested Hotshots filter vs Hotshot CAI with POP and there was no power difference. The POP aapeared to be a higher quality element and seemed like it would filter better, this is just subjective though and I have no data to support this.
The Maf is clearly closer on the PR piping. Is there any chance that maybe you have a different HS intake? Maybe one that was made for testing purposes?
That picture on the HS site is of a low port intake.
1991 Sentra SE-R
No but I have a real old PR intake, like maybe the second low port ever made so there is a posiblity that mine is different than whats out now.
