Old 06-07-2006, 08:07 AM   #1 (permalink)
jerryeads
Is an SE-R/VE a VE-R?
Thinkgeek car computer
Thought some of you fellow geeks might like to know this exists - at thinkgeek.com, a cool place that seems to be run by good people. Says it only picks up OBDII data, so looks like it won't work on my classic.
http://www.thinkgeek.com/interests/dads/8426/
From the listing:
As a general rule geeks like to have access to as much data and statistics as possible. We pretty much figure this applies to a geek's motor vehicle as well. So, to allow you to access extra information about your car we would like to introduce the ScanGauge II Automotive Computer. This gadget is easy to install and provides a set of digital gauges, a comprehensive trip computer, and an engine trouble code scan tool.
The digital gauges mode displays four different properties on the screen (for example, fuel economy, battery voltage, coolant temperature, and engine speed). The trip computer tracks your vehicle's maximum speed, average speed, driving time, driving distance, trip fuel economy and several other pieces of trip data. The engine trouble code scan tool lets you read standard engine trouble codes as well as clear the "check engine" light and other warning lamps.
The ScanGauge II is simple to use and install and mounts in, on or below the dash. It plugs into the diagnostic OBD-II connector found under the dash on 1996 and newer cars and light trucks. The functions are accessed viaa simple on-screen menu interface. There is an automatic delayed power-down after engine shutoff and automatic power-up when engine is started. User and vehicle settings are automatically saved.
Also has these features.
Reads engine trouble codes and can reset the "check engine" light
Trip computer that automatically tracks various elements of trip data
Expanded digital gauges (fuel economy, battery voltage, coolant temp., etc.)
No tools needed to install - plugs into the OBD-II diagnostic connector
Simple menu driven operation
User-settable backlight color and brightness - 126 possible color/brightness settings
Batteries not required
Dimensions: 4.8"W x 1.5"H x 1"D
Connector cord length: 6 feet
User adjustable contrast and update rate (slow, normal and fast)
ScanGauge II compatibility list
Big display - 50% larger than the original ScanGauge
Cable detachable - can be connected on the back or side - RJ45 connection
ScanGauge II to USB Interface available in August 2006. Allows data logging, field upgrades, data downloads and more
One year manufaturer warranty
'93 B13, etc.
do it over and over again?
Old 06-07-2006, 04:54 PM   #2 (permalink)
Melissa
Soon!
I saw that in my email today too. The one thing I've learned about ThinkGeek is that it's a great place to browse, and once you find something you like, hunt for it elsewhere, because TG is expensive.
Melissa is offline   Reply With Quote
Old 06-08-2006, 02:21 AM   #3 (permalink)
junknstuff
nx-less
Trader Rating: 15 (100%)
interesting hardware. i'd buy it for kicks, but not for that price. and im not obdII
- jason
damn you eKool
junknstuff is offline   Reply With Quote
Old 06-08-2006, 02:25 AM   #4 (permalink)
iMagnusX
SE. Period.
uh, is that MPG they advertise like a BMW-only feature? I don't think that shows up on regular OBD-II.
and uh, calumsult vs. this?
iMagnusX is offline   Reply With Quote
Old 06-08-2006, 05:05 AM   #5 (permalink)
coach I am a moderator
Tired!
coach's Avatar
Trader Rating: 40 (100%)
Calumsult for me!
Brent
Old 06-10-2006, 09:24 PM   #6 (permalink)
jerryeads
I wouldn't do it either, even if OBDII; too much else yet to spend bux on. BUT I can't drive around all the time with the laptop hooked up either - - - -. BUT, cute.
Old 04-23-2008, 05:39 PM   #7 (permalink)
Dan9
My car is out of storage.
Trader Rating: 18 (100%)
http://www.scangauge.com/
Seems maybe it has more features now than it did?
They are selling them for 169.95 shipped (in US I guess). My friend was thinking of getting one of these for his Kia, is it a good buy?
D
Looking for peace of mind
