ok i have a 94 xe.....the power plug is a dual prong and i cant find an adapter.....a single prong pulls out but for some odd reason i think it needs both for the new radio to operate......any info?
i think the power plug you are refering to is the antenna plug, which doubles as a ground point for the radio. you need an adapter to make it work with an aftermarket radio
winter in new england sucks cause you have to raise the cars up and put snow tires on. But, you do get to play in the snow.
