Old 11-21-2006, 01:05 PM   #1 (permalink)
FWD PWNAGE IS HERE!
Where do I find these wires for remote start system?
Instructions say to locate...
H2/1 - Channel 2
H2/2 - Lock #87A Normally closed
H2/3 - Lock #30 Common output
H2/4 - Lock #87A Normally Open (Input) 15A
H2/5 - Unlock #87 Normally closed
H2/6 - Lock #30 Common output
H2/7 - Unlock #87A Normally open (Input) lopped back to H2/4
'93 240SX - Stock for now
'95 G20 - The DD - 210K and counting
'96 G20 - Beating up the streets of SL,UT.. watch out - 334WHP/313TQ
www.UtahNissans.com
www.RallySportDirect.com
SR20 Inside is offline   Reply With Quote
Old 11-21-2006, 11:56 PM   #2 (permalink)
A Non-cocky Spec V Owner
those are the wires for the internal door lock relay. depending on the car you change how you wire them. what car are you putting this on??
'02 Aztec Red Spec V - 1st Turbo Spec V - 264.6 whp & 250.2 ft-lbs (first setup)
324 whp & 306 ft-lbs @ 10.5 psi on SC-61
'93 Aztec Red SE-R
wedge02specv is offline   Reply With Quote
Old 11-22-2006, 12:01 AM   #3 (permalink)
FWD PWNAGE IS HERE!
95 G20
So if I did my research right then the door lock and door unlock is behind the passengers kick panel behind ecm where ever the hell that is. SO I am supposed to wire from the remote start system to that unit? I wonder why they give you wires so damn short in that case.
Old 11-22-2006, 12:07 AM   #4 (permalink)
yeah the lock wire is orange/black and the unlock is orange/blue, and yes it is in the passengers kick panel, you'll have to extend the lock wires to the kick panel.
you'll wire lock 87a and unlock 87a to ground (if this is a dei unit, those wire will be purple and purple/black) and wire lock 30 (which should be green/black) to orange/black and wire unlock 30 (which should be blue/black) to orange/blue, just leave the rest not attached you anything and tape them off
Old 11-22-2006, 12:10 AM   #5 (permalink)
FWD PWNAGE IS HERE!
just to confirm the g20 is the same as a sentra with the one-wire system ( cut to lock, ground to unlock) ? Isn't that just what you described above?
Old 11-22-2006, 12:12 AM   #6 (permalink)
no it's a two wire negative trigger system
lock is orange/black and unlock is orange/blue
Old 11-22-2006, 12:16 AM   #7 (permalink)
FWD PWNAGE IS HERE!
Pardon my stupidity here but this is a two wire negative trigger system?
Old 11-22-2006, 12:17 AM   #8 (permalink)
yep that's it, that's what is was trying to describe, but just hook the green and blue to the wires i told you to
Old 11-22-2006, 12:24 AM   #9 (permalink)
FWD PWNAGE IS HERE!
sweet
