naw naw the actual clip that goes on the sensor i need to cut off my GA harness and extend thoes wires to the back of the cluster and connect them 2 wires two the other 2 wires that control that sensor i think he told me they were 2 solid wires green and red
no but i *** i found out a easyer way to mess with my speed sensor from the cluster which is way better then pulling a harness and looking for this and that ...at least it staid on the subject of the cluster itself lol
no i dont have a speedo cable .. let me brake it down. My car is a 94 B13 GA16 which already has the electric speed sensor! upon doing the GA to SR swap the tranny that i got was from a G20 which also came with a electric sensor. The clips and plugs are diffrent from Sr to G20 as you can see on the pics that sinistersntra put up. The Harness came from a 91-92 Ser which was cable driven. so that means i dont have a clip for the speed sensor because it was calbe driven. so i take the clip that goes in the SR speed sensor sensor cut the wires.. take the 2 wires from my speedo(the solid red and the solid green one run it through the fire wall connect them to the harness and clip it in and presto !
My car was 94 auto GA and I wanna put in a 91-92 nx2000 cluster...but my 5speed tranny is cable-driven...
...I looked carefully at the wiring diagrams and as it stands I'd need to re-pinout just about every wire.
Did just getting a section of body harnness work?
On the diagrams the differences were slight GA-SR but the biggest diff was between cars that came with a tach and didnt come with a tach, regardless of motor.
