Old 01-14-2007, 07:11 PM   #1 (permalink)
Zeek234
Boost Build
Help! my headunit isn't working!
I just recently installed my rockford speakers and kenwood reciever but when i wired up the new head unit and plugged it into the stock stuff it didn't work, crutchfield gave me all the harnesses that should have worked like a dream but somehow my old stock radio still works but my new one doesn't we soildered the harness correct and grouded but still got nothing, any sugesstions and advice will help Thanky you!!!!
_________________
Project 91'
Zeek234 is offline   Reply With Quote
Old 01-14-2007, 09:03 PM   #2 (permalink)
Joaquin714
FTW
Simple stuff first. Check fuses!! If you have a probe tester it will make it loads easier...
1967 Datsun Roadster 1600- Weekend toy
1991 Nissan Sentra B13 SE-R- avenir powered.
1996 Nissan 200sx B14 SE-R- VVL power in process
www.myspace.com/jockin714
Joaquin714 is offline   Reply With Quote
Old 01-14-2007, 09:16 PM   #3 (permalink)
Zeek234
Boost Build
I have a multimeter, but power gets to the old radio but not the new one like what the hell ? lol
Old 01-14-2007, 09:16 PM   #4 (permalink)
Zeek234
Boost Build
My fuses are fine
Old 01-14-2007, 10:37 PM   #5 (permalink)
snowballz
banned
make sure all the harness connectors have there plugs pushed in tight (the metal on the end of the wires that connect to the clip) sometimes when u put in the clip it pushes them out. and hook up a new ground. dont use ur stock ground. i can tell u that much. expecialy if ur using aftermarket speakers as you need way more of a ground than just a little 28 gauge wire! and make sure they didnt accidently send a different year. check ur stock wiring with a FSM and then check it to your radio.
snowballz is offline   Reply With Quote
Old 01-15-2007, 08:33 PM   #6 (permalink)
Zeek234
Boost Build
Thanks man
Old 01-16-2007, 09:06 PM   #7 (permalink)
Promaine
It just seems like Crutchfield sent the wrong harness because it's wired correctly, did you get one at best buy yet?
Promaine is offline   Reply With Quote
Old 01-16-2007, 10:22 PM   #8 (permalink)
snowballz
banned
you figure anything out on this yet?
Old 01-17-2007, 12:27 AM   #9 (permalink)
SERGAN
'95 G20t, So i got wiring harness that was cheap and looked cheap too from BB.
Could someone please shoot me wiring diagram for a non-Bose stereo? I cant figure out amplifier power.
It says blue/black -, and blue/white + for power on and ground on the harness. But to what wire out of stereo i hook them up too? My stereo seem not to have extra 12v, just red and yellow.
Well lets say i'll supply voltage to those blue guys, but what those two grey wires with connectors coming out of the amps?
Sorry if i sound very confusing, and just post me a diagram. Thanks!!!
SERGAN is offline   Reply With Quote
Old 01-17-2007, 01:33 PM   #10 (permalink)
Zeek234
Boost Build
It seemed like my head unit was DOA so im going to send it back to them
