Old 03-12-2007, 02:53 AM   #1 (permalink)
Steve-0
Rattling from sound system tips....
well i have a 2001 se, i was wondering if people have tips and tricks to help stop rattles.... any other tips would be good too... i fingered this would help us all out i guess...
one i have is tighten all the spoiler bolts... it stopped a bit of the rattling from the spoiler...
Steve-0 is offline   Reply With Quote
Old 03-12-2007, 10:43 AM   #2 (permalink)
stephenjk13
Trader Rating: 23 (100%)
i think you posted in the wrong section
92 B13 ser:Black sr20VE
95 4Runner:Black
79 Ford f-150: Brown-wheelin machine
stephenjk13 is offline   Reply With Quote
Old 03-12-2007, 10:52 AM   #3 (permalink)
PhorB13
SR20DEviant
Trader Rating: 20 (100%)
You should put sound deadening (Dynamat) on the trunk lid & any other place that rattles.
PhorB13 is offline   Reply With Quote
Old 03-12-2007, 11:01 AM   #4 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 97 (100%)
Moved to the Audio section.
Old 03-13-2007, 11:33 AM   #5 (permalink)
wellitsover
SE-R NUT
Phor is right I used dynamat on the trunk lid and secured the rear deck panel now the only rattle i get is my keys.
wellitsover is offline   Reply With Quote
Old 03-15-2007, 07:37 AM   #6 (permalink)
budsang1
Beware....THE BEAR!!
budsang1's Avatar
Trader Rating: 31 (100%)
I put 70sq ft of brown bread into my trunk, and onto my trunk lid. Stopped damn near every rattle i had
budsang1 is offline   Reply With Quote
Old 03-15-2007, 10:14 AM   #7 (permalink)
sonny
SR20DEtroit
There is a point when your subs are so loud that they drown out the rattles.... you just need a louder sub/amp combo.
Alternatively, Dynamat (overpriced IMO) or similar should solve your problem... also, take of the lisence plate and see if that makes a diff. If it does, you need to do some sound insulation there.
sonny is offline   Reply With Quote
Old 04-12-2007, 06:18 PM   #8 (permalink)
Paidinfull
Go to home depot buy spray foam. Cover your trunk with a drop cloth (it gets messy). Remove your trunk panels, and spray a little in every hole. The reason why I say spray a little is it expands in a couple seconds, so be careful.
Go here to view my car.
http://www.cardomain.com/ride/2553583
Paidinfull is offline   Reply With Quote
Old 04-18-2007, 06:32 PM   #9 (permalink)
93sentra
1995 240SX
Right now im in the process of installing dynamat along with those foam baffles crutchfield sells. This should stop the rattling of my door speakers and the deck speakers. Also I would consider tieing down any loose wires in your trunk with zipties due to amp instalation or speaker installation. Im my system these wires made this real hi pitch rattle which no one bearly nitices but it bothered me so.
Cheated on the sentra with a 240 , I wouldn't have it any other way.
Fully built DET is on the way.
93sentra is offline   Reply With Quote
Old 04-19-2007, 01:46 AM   #10 (permalink)
thehardknoxlife
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
Sign up for DIYMA.com and you get 20% off the best priced deadener available. Can be had right around $100 for 60 sq ft.http://www.sounddeadenershowdown.com/heat/
thehardknoxlife is offline   Reply With Quote
