Old 05-27-2007, 12:45 AM   #1 (permalink)
How can I convert a 2 amp charger to a .75 amp charger?
I need to convert my car battery charger into a motorcycle battery charger. I also need to figure out how to measure AMPS with my voltage tester, if that is even possible. I don't have the instructions any longer. The setting I thought I used doesn't seem to work. Maybe it's broken. I figure I can get a resistor of some sort and just put that inline on the Positive lead of the charger but I don't know if that will work, if I need it on positive and negative or anything about it really.
Steve
06 G35 6MT
Old 05-29-2007, 04:54 AM   #2 (permalink)
build completed...
Trader Rating: 26 (100%)
What kind of voltage tester. If you have a DMM, you can test up to 10A, fused.
The only way to reduce aperage would be to use a resistor. I would recommend a variable resistor, so that you can increase the current should you need to use it on a car again. Where to use the resistor, I can't tell you for sure. I would assume that you'd want it at the output of the charger.
SR20DEEP in TX
