Old 08-12-2007, 04:16 PM   #21 (permalink)
naddie
Super Advanced Newbie
Originally Posted by KrAsH View Post
I'm currently working on the car, and I'm a bit confused...
B15 pin 115 is now connected to 58, and the OBD reader is still not working.
Pins 22 and 111 were already connected, so I did not worry about them. However the B15 FSM says that pin 111 is the sensor power supply (5V signal). Are you sure we are supposed to connect the 5V source to a ground? On my car, the B14 pin 39 is connected to B15 108 (ECM ground)...
Sorry, you're right - pin 111 is something else - I mis-traced. Pin 39 is a good ECM ground to use if you ever needed it. I never had to touch 111 either.
naddie is offline   Reply With Quote
Old 08-16-2007, 03:55 PM   #22 (permalink)
KrAsH
Racing Addict
...ok, so I'm still with this issue right now.
Just so I'm sure it's not the reader that is not working, anyone know what ISO protocol the B14/P10 ECUs use?
Matt
2001 Sentra SE/pp (SR20VE powered)
Trac Racing Depot
KrAsH is offline   Reply With Quote
