Old 08-09-2007, 08:10 PM   #1 (permalink)
speakers all cutting out
alpine mrp-f450 amp
polk db675 (rear)
polk db6500 (front)
alpine cda-9883 headunit
everything worked fine for the first couple of weeks i had the system but now it cuts out more and more. all of my speakers randomly stop working all at once at random times. the amp still has power and so does the headunit. any ideas what could be causing this? could it be a bad ground on the amp?
94 G20t - Hotshot CAI, SSAC Header, 19* Timing, VRS/Magnaflow Catback, TWM Shifter, JWT S4's, Prothanes, Euro Tails
Man your car has been through a war over the last year!
couldnt have said it better myself!
apoc987 is offline   Reply With Quote
Old 08-09-2007, 08:40 PM   #2 (permalink)
Keo
huh??
Keo's Avatar
Trader Rating: 42 (100%)
when I had that problem it was the amp not getting enough ground. check to make sure it's on tight
Old 08-09-2007, 11:09 PM   #3 (permalink)
fu*k you auto*****s
Trader Rating: 5 (86%)
Sounds like a ground problem, although it could also be either remote/12V too, so check all those. Did you do the install yourself? or did you have it done?
fu*k you autoforums.
NismoB14SX is offline   Reply With Quote
Old 08-11-2007, 11:23 PM   #4 (permalink)
did it myself. i have a p10, got any good ideas for a better grounding spot?
Old 08-12-2007, 12:03 AM   #5 (permalink)
fu*k you auto*****s
where is it grounded now?
Old 08-12-2007, 12:17 AM   #6 (permalink)
under the back seat behind a bolt that holds a seat belt in. i scraped off the paint and cleaned the surface where the ground cable was touching metal. the cable was only 3 feet long so i couldnt find a better place. could this be what is causing it to keep cutting out and the amp to lose power?
Old 08-12-2007, 01:21 AM   #7 (permalink)
fu*k you auto*****s
could be. try to find a closer ground, somewhere within the trunk, the latch, for instance.
Old 08-12-2007, 12:17 PM   #8 (permalink)
well the amp is mounted on the back of my back seat so the ground is only 1.5 or 2 feet away. the latch would be much further.
Old 08-15-2007, 11:07 AM   #9 (permalink)
the fo do
You could try putting a backcap or a capacitor on and it will solve your problem. Amp could be overloaded as well , so that could be why it cuts out. More than likely you just need a backcap/capacitor.
99 SE-L
91 intake cam/bluebird t25/Calum ecu/370cc injectors/walbro 190/3inch dp/Greddy Catback/JWT PP w/ SE Disc/Prothane mounts
se-riousclassic is offline   Reply With Quote
Old 08-15-2007, 10:20 PM   #10 (permalink)
found the problem. my in-line fuse in the power cable had come loose a little bit. just enough so that it wasnt providing the amp with the proper voltage.
