Old 08-16-2007, 10:27 AM   #1 (permalink)
FunnyJr
Amp power wire routing?
Anyone know where the passage is in the firewall on a B13 to route a power wire (for amp) through.
thanks
FunnyJr is offline   Reply With Quote
Old 08-16-2007, 11:38 AM   #2 (permalink)
wellitsover
SE-R NUT
run it under the car by following the fuel lines. what gauge wire are you using?
200sx - Turbo, NOS, Carputer
350z - Pioneer HU
wellitsover is offline   Reply With Quote
Old 08-16-2007, 11:47 AM   #3 (permalink)
chriscar
merely a flesh wound
chriscar's Avatar
Trader Rating: 97 (100%)
Run it along with the stock wire bundle through the fender.
Through the firewall grommet.
Inside the wire trough.
Old 08-16-2007, 11:49 AM   #4 (permalink)
sonny
SR20DEtroit
Very clean, Chris.
sonny is offline   Reply With Quote
Old 08-19-2007, 12:50 PM   #5 (permalink)
FunnyJr
Thanks Chris for the helpful pics. Greatly appreciated
Old 08-19-2007, 03:53 PM   #6 (permalink)
tearoff guy
Nx is my drug addiction
tearoff guy's Avatar
I think Chris hit it good for ya,,, I had to run 0 gauge for my set up and I went through the firewall next to the throttle cable then down the side of the car in the same channel as he did,,,, was'nt easy but it fit,,,, LOL BY THE WAY if anyone is interested in a nice package for a Nx ,, hit me up and I'll post some pic's...
1991 Nx1600 hardtop 2.0 swap BC Stroker project for 2008
1992 Nx2000 my wake up call
JWTpopcharger,SSAC2.5 header/down pipe VRS CATBACK/Magnaflow,KYB AGX-Hyperco Gen II's,F1 stage3 clutch/flywheel,ES/Prothane motor/tranny mounts, R1 concept front/rear drilled/slotted rotors,AXXIS pads,clear side markers,Maxxim/wheels/205/40/16NittoNeoGens,RedlineMT90,Mobile1,Fstb
tearoff guy is offline   Reply With Quote
