Old 09-28-2007, 02:35 PM   #1 (permalink)
hiimrif
Two injectors not receiving a signal????
So I have a 94 Sentra GA and Cyl. 3 and 4 injectors aren't receiving a signal. I recently did a port and polish job on it and put all back together and it ran fine. Then I tried to put a b14 Maf on it and drove it around for a few miles before I decided it didn't run well enough to keep on. AS I was pulling into my driveway it started to misfire. So I put the b13 maf back and cranked it still misfiring. Checked plugs and wires was getting spark so i unhooked the injectors one at a time nothing changed when I unplugged 3 & 4 so I swapped them with 1 & 2 to see if it was the injector and the misfire still happened on 3 4. I think i might have a cut wire somewhere and was wondering if instead of finding it could i just rewire the injectors straight from the ecu and if so would i need to put any resistors in. Also I was thinking that it might be my camshaft position sensor that had something blocking the slits for 3 4 so the ecu wasnt sending a signal at all. Just wondering if any one else has ever had a problem like this. I appreciate any input. Thanks
hiimrif is offline   Reply With Quote
Old 09-28-2007, 10:12 PM   #2 (permalink)
TeKKiE
work in progress...
Trader Rating: 26 (100%)
Bump for the guy. This would probably be better in the SENTRA SE section, BTW...
SR20DEEP in TX
Old 09-28-2007, 10:44 PM   #3 (permalink)
NismoB14SX
fu*k you auto*****s
Trader Rating: 5 (86%)
Sentra SE? But they're SR20?
fu*k you autoforums.
NismoB14SX is offline   Reply With Quote
Old 09-28-2007, 10:53 PM   #4 (permalink)
NismoB14SX
fu*k you auto*****s
searching helps.... I searched "injector problems" and within five minutes found something that may help.
http://www.sr20forum.com/sr20de-tech...ot-firing.html
please. please use the search tool!
Old 09-28-2007, 10:55 PM   #5 (permalink)
NismoB14SX
fu*k you auto*****s
and another...
http://www.sr20forum.com/general-sr2...ot-firing.html
Old 09-29-2007, 11:51 AM   #6 (permalink)
hiimrif
Thanks for the links but what I was really wondering was if I could just hard wire my injectors straight from my ecu and in so doing would I need to put any resistors in as I don't want to blow my injectors. I read somewhere in another post about putting a resistor when wiring injectors and was just wondering if I had to that on stock injectors or not.
