Old 10-02-2007, 02:48 PM   #1 (permalink)
sr20ve beast
Never seen this before
I have a 400.2 rockford amp and a P3 10 sub. I wired up the amp mono 2ohms. The thing im not sure how the sub is wired up. What i mean is if its running 2 or 4 ohms right now.
So heres the problem. I have the amp turned up pretty high and i will turn the cd player up the 1, i usually run it at 23. Every couple of seconds the sub pulses, extending the sub all the way and then repeating every couple of seconds. when it does this it is not putting out any sound. Its really slow. What is going on?
sr20ve beast is offline   Reply With Quote
Old 10-02-2007, 04:04 PM   #2 (permalink)
NismoB14SX
fu*k you auto*****s
Trader Rating: 5 (86%)
you're getting feedback. check your grounds. what type of wiring are you using?
fu*k you autoforums.
NismoB14SX is offline   Reply With Quote
Old 10-02-2007, 04:07 PM   #3 (permalink)
sr20ve beast
I'm using some 8 gauge i had lying around. So you saying i need to ground my amp better?
Old 10-02-2007, 06:25 PM   #4 (permalink)
sr20ve beast
Checked my ground and it likes good. How well do these amps need to be grounded.
Old 10-02-2007, 07:16 PM   #5 (permalink)
NismoB14SX
fu*k you auto*****s
if it's not the ground, then maybe the RCA's you're using. I'll post up a site..
http://www.caraudio.com/forum/showthread.php?t=198477
there.
Old 10-02-2007, 07:24 PM   #6 (permalink)
sr20ve beast
Thanks for the site. I will have to try this out and see what happens
Old 10-02-2007, 07:42 PM   #7 (permalink)
NismoB14SX
fu*k you auto*****s
okay, let us know!
Old 10-02-2007, 09:13 PM   #8 (permalink)
tearoff guy
Nx is my drug addiction
tearoff guy's Avatar
you have what is called reverse puliarity,, you have the amp wired wrong..
goto www.Rockfordfosgate.com
they have all your answers about the P3 and your 400.2
when a sub does that it means your amp is going into protect... good luck
1991 Nx1600 hardtop 2.0 swap BC Stroker project for 2008
1992 Nx2000 my wake up call
JWTpopcharger,SSAC2.5 header/down pipe VRS CATBACK/Magnaflow,KYB AGX-Hyperco Gen II's,F1 stage3 clutch/flywheel,ES/Prothane motor/tranny mounts, R1 concept front/rear drilled/slotted rotors,AXXIS pads,clear side markers,Maxxim/wheels/205/40/16NittoNeoGens,RedlineMT90,Mobile1,Fstb
tearoff guy is offline   Reply With Quote
Old 10-03-2007, 10:47 AM   #9 (permalink)
se-riousclassic
the fo do
Wired the amp up mono? Do you mean bridged? When you bridge an amp the ohm level is dropped double (e.g. 2=1 , 4=2). Is the speaker a dual voice coil?
99 SE-L
91 intake cam/bluebird t25/Calum ecu/370cc injectors/walbro 190/3inch dp/Greddy Catback/JWT PP w/ SE Disc/Prothane mounts
se-riousclassic is offline   Reply With Quote
Old 10-03-2007, 11:16 AM   #10 (permalink)
93sentra
1995 240SX
Check crutchfields wireing diagrams for your sub and amp combo. Depending if its dvc 2ohm, 4ohm or svc 2ohm, 4 ohm. This happened to me before when I wired my sub for an impedence that my amp could not handle in mono mode.
Cheated on the sentra with a 240 , I wouldn't have it any other way.
Fully built DET is on the way.
93sentra is offline   Reply With Quote
Old 10-03-2007, 11:25 AM   #11 (permalink)
sr20ve beast
Yeah is a DVC 2ohm sub. It came prewired so im going to have to open it up tonight and check it out. Not sure if the sub is wired for 2 or 1 ohms.
As for the amp it is bridged and running 2 ohms.
Old 10-03-2007, 05:49 PM   #12 (permalink)
tearoff guy
That amp you have is 2 ohms stable if you have a DVC 2 ohm sub and bridged the amp you dropped it down to 1 ohm,, it has went into protect,,,,,,,
GO TO WWW.ROCKFORDFOSGATE.COM
Old 10-03-2007, 07:04 PM   #13 (permalink)
sr20ve beast
Well i got an answer from rockford and when you bridge this amp it as 4-ohm Bridged/mono. Looks like i need to open up the sub and see how it is wired. Hope this is the answer to my problem, if not im not sure what else to try.
