Old 12-01-2007, 12:07 AM   #1 (permalink)
skeeter149
Tryin' To Be Like You
ok so i bought a jvc kd-nx5000.... how and where do i splice into the vss on a auto?
Vehicle Speed Sensor
ok so i figured out my other question so here we go. for the gps to calibrate i need to hook this bad boy into the vss wire. now i found that on the ecu it s pin 26 and the fsm say it pu/r in color. i assume that would be purple/red. but anyway the question was is that where i should do it or does anyone have better idea? thank you pics are always lovely. this is a 99 sentra se-l auto. thanks
http://mobile.jvc.com/product.jsp?mo...hId=133&page=1
thanks for the help. rico.
Originally Posted by Shawn B
Purple monkey Fritos elbow dishwasher cigarette can-opener!
Acorn lug-wrench carpet vibrator Gatorade?!?
i am about to make that my sig shawn if you will allow it?
hell i did it so if you want me to i can get rid of it but i thought it was hella funny
skeeter149 is offline   Reply With Quote
Old 12-01-2007, 10:17 PM   #2 (permalink)
NismoB14SX
fu*k you auto*****s
Trader Rating: 5 (86%)
do it either at the speedo itself, which may be easier to get to, or the ECU, whatever one you choose.
fu*k you autoforums.
NismoB14SX is offline   Reply With Quote
Old 12-01-2007, 11:32 PM   #3 (permalink)
esspecv
Moving against the grain.
Hope this will help.Look for ***
1999 NISSAN SENTRA 4DR SEDAN
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery PINK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground GRAY (-) RADIO HARNESS
THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
Illumination RED/GREEN (+) RADIO HARNESS
Dimmer RED/YELLOW (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) BLUE
RF Speaker (+) WHITE
RF Speaker (-) BLACK
LR Speaker (+) LIGHT GREEN
LR Speaker (-) VIOLET
RR Speaker (+) BLUE
RR Speaker (-) PINK
Amp Location NOT LIKELY
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Security
Battery GREEN (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/RED (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger RED/WHITE (-) DRIVERS KICK PANEL
Trunk Trigger RED/SILVER DOTS (-) TRUNK LIGHT OR SWITCH
Alarm Disarm GREEN/YELLOW (-) DRIVERS KICK PANEL
Alarm Arm LIGHT GREEN/RED
Parking Lights RED/BLUE (+) CONN ON TOP OF FUSE BOX
Convenience
Headlights-Lo GREEN/ORANGE (+) PNK/BLU SEPERATE WIRE AT STEERING COLUMN
Trnk Release N/A
Remote Start
Ignition 2 BLACK/BLUE (+) IGNITION SWITCH HARNESS
Accessory 1 BLACK/PINK (+) IGNITION SWITCH HARNESS
Tachometer GREEN/YELLOW OR (AC) GREEN AT COIL OR ECM POS 3 DR. SIDE CONSOL
***Speed Sense VIOLET/RED 2000 (AC) DR. SIDE OF CONSOLE AT ECM POSITION 26
Brake Lights RED/GREEN (+) AT BRAKE SWITCH
Horn BROWN (-) AT STEERING COLUMN HARNESS
Modules
WIRE LOCATION
Module 1 ON DRIVERS SIDE OF CONSOLE
Doorlocks/Windows
Power Unlock VIOLET/SLV DOT (-) NEGATIVE DOOR LOCKS
PowerLock GRAY (-) WHT HARNESS IN DRIVERS KICK PANEL
Driver Mtr Unlock YELLOW (+) RIGHT OF STEERING COLUMN
Driver Mtr Lock RED/YELLOW (+) RIGHT OF STEERING COLUMN
Pas Mtr Unlock WHITE/RED
LF Window Up LF:GREEN
RF Window Up RF:RED/WHITE DRIVERS SWITCH
LR Window Up LF:BLUE
RR Window Up RF:RED/BLACK
Note:I make no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights.I disclaim all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
esspecv is offline   Reply With Quote
Old 12-05-2007, 12:02 PM   #4 (permalink)
skeeter149
thank you very much that will help.
Old 12-06-2007, 04:23 PM   #5 (permalink)
esspecv
No prob.
