Old 01-02-2008, 10:19 AM   #1 (permalink)
NismoB14SX
fu*k you auto*****s
Trader Rating: 5 (86%)
Great anti-theft idea!
okay, while lying in bed last night, I had this great idea pop into my head to protect your aftermarket, or even stock headunit!
Okay, first, get your radio and unscrew one of the chasis screws. Next, get some pipe strap, the metal kind with holes, like this:
If needed, use a washer, and attach one end of the strap to the headunit chasis. Install the until just as you would, and keep the strap behind it. Now, with the radio installed, find the strap behind the dash, and now locate a bolt/nut to attach the the other end of the strap to, out of sight. Best place is behind the dash itself, as level with the radio as possible. Pull the strap as tight as you can get it, and bolt it down. cut the excess off of the strap, and reinstall everything. This should greatly help in keeping your radio in your vehicle, and out of the hands of others.
fu*k you autoforums.
NismoB14SX is offline   Reply With Quote
Old 01-02-2008, 10:21 AM   #2 (permalink)
LOUROK
Criminology
LOUROK's Avatar
Trader Rating: 19 (100%)
good idea!!!!!!!
1. 95 200SX SE-R -- T-25/Rebuilt usdm motor/Calum ECU/tein ss/ur crank pully/jwt clutch, pressure plate & flywheel/nismo lsd/stromung 3 inch cat-back/S4 cams/5zigen Fn01r-c wheels
2. 2004 4wd Toyota Matrix
LOUROK is offline   Reply With Quote
Old 01-02-2008, 11:04 AM   #3 (permalink)
fireisiah
the good installers use a method like that already. but between detachable faceplates coming mainstream yrs ago, and the cost cutting of places like best buy, its become less common thou.
fireisiah is offline   Reply With Quote
Old 01-02-2008, 01:32 PM   #4 (permalink)
squirlz
Come get your ham Tina!
Yup, the place i use to work at did this on almost all installs. It also helps prevent skipping.
It seems that some people have been spoon feed their whole lives, It is societies job to teach them how to use the spoon for themselves.
squirlz is offline   Reply With Quote
Old 01-02-2008, 08:17 PM   #5 (permalink)
bobbyisking
KASSANOVA!!!
Trader Rating: 37 (100%)
but if they can't take off the deck, then they may fu*k up some other stuff in the car, like stab the dash, steering wheel, throw a brick on the windshield, haha... u know what i mean, like, if you can't get something, then fu*k it up more...
92 Dark Gray Sentra SER
92 Red Sentra SER
Old 01-02-2008, 08:21 PM   #6 (permalink)
fireisiah
great mentality u got there. sounds like u speak from personal experience.
isnt there a honda forum more suited to ur type?
Old 01-03-2008, 05:40 AM   #7 (permalink)
XxToKeSxX
XxToKeSxX's Avatar
Trader Rating: 42 (100%)
Bingo... If someone wants your stuff, and they break into your car, they are going to find one way or another to get it... or they will ef your stuff up.
Well I'm speaking from personal experience... I used to lock my glove compartment a while back. I didn't have anything in their besides my registration... well the person that broke in decided he wanted to find out for himself. Screwdriver, and prybar did the trick. Now instead of being out only a radio, I was out a dash too.
It's common sense. Stop trying to make people look stupid for common intuition.
1998 SE-R | S3Rs/I/H/E/M | 99.9% Daily Driver | Rubí DeL FuegO
1991 nX-T | My Boost Slut | 00.1% Daily Driver | The Deviled Egg
Shift_Down to 2 Vehicles...
Old 01-03-2008, 06:50 PM   #8 (permalink)
Rob
VQ35 Powa!!
people still steal car radios?
218WHP/228 TQ WAI only 02 6MT A33B
Old 01-03-2008, 07:24 PM   #9 (permalink)
squirlz
Dont give them a reason to break in, hide things from plain view, get a good alarm properly installed and dont park in bad areas. Dont leave things of value on the seats and try to keep things as stock looking as possible. There are precautions you can take, i know you can only go so far but be as careful as possible.
Old 01-03-2008, 08:01 PM   #10 (permalink)
fireisiah
"It's common sense. Stop trying to make people look stupid for common intuition."
yeah, its common sense to keep things out of view, but u cant possibly tell me that by adding the "haha" in his sentence that hes not thinking its funny to screw someones car up. if he's been the victim of a radio theft, i seriously doubt hed be laughing about it and the things people would do. and dont u think the"....." implies that even more?
Old 01-08-2008, 05:48 PM   #11 (permalink)
zipstrips
4th sr20 and counting..
zipstrips's Avatar
seriously!? one only time i got broken into, they left everything alone, new radio, gauges, even a sparco wheel on the floor!.. they wanted it all or nothing! i did lose my factory glass and they killed my ignition colum.
SHIFT_multiplication!
98. W10 w/ S4's!
96. W10
95 Celica, 3SGTE
Old 02-09-2008, 10:31 PM   #12 (permalink)
paul62462
I am an installer by trade & I can tell from seeing many cars with that type of "security" as well as razor blades on the back to the never popular S.D.M. (smoke defence machine which I think my shop has the remains of one still) that when they cant get what they came for they will take revenge on ANYTHING else in or outside of the car!! One guy about 5 yrs ago had a radio that cost $400 & he put a strap on the back & soldered thumbtacks to the back & bottom of the radio (bottom of the radio was in a pocket which could be popped out) & he thought it was safe. Well, within 6 months they tried to get it & when he returned, the radio was there...sort of... the theif took his own lug wrench & punched it through the radio!!! As well as his instrument cluster, his heat/ac controls dashboard, windsheild (drivers window was how they got inside in the first place) as well as blood all over! All they got away with was about 10 cd's & his insurance card! In the end last we heard he had $1900.00 + damage all for a $400.00 radio! & the last insult??/ they left a note saying "nevermind you can keep your radio" SO MY ADVICE IS TO MAKE THE AFTERMARKET RADIO RECESSED AS POSSIBILE & MAKE A FAKE CHEAP RADIO COVER IT!! you can do this by buying the cheapest ugilest radio you can get cut off the front glue on the knobs & or buttons & use a thin piece of plastic or cardboard to go in the cd/tape slot to hide your investment & hide ANYTHING that make them think differently IE: remote for radio cd's ect. this is my best advice to you!!.....good luck all!!! Paul
paul62462 is offline   Reply With Quote
Old 02-25-2008, 08:26 PM   #13 (permalink)
91SentraSeR
Smashin In Our SE-R's
wtf? hes just giving his personal opinion. If you dont like it get the hell out, at least have an input thats related to the topic.
what bobby was saying, its true. Where my dad used to work, they left the cash register open so if a thief did really wanna take anything he wouldnt break it open and find nothing, he would just clearly see that the register is empty and hopefully take off.
White 91' Sentra SE-R
SE-R20
91SentraSeR is online now   Reply With Quote
Old 02-26-2008, 01:51 AM   #14 (permalink)
SuperblkStalion
Very bling bling
i have the final answer...a combo of these three...
you can close this thread now.
SuperblkStalion is offline   Reply With Quote
Old 02-26-2008, 02:30 AM   #15 (permalink)
jen36
Im Not A Chick
hahahahahaha^^^^^^^^^
B13 XE with sr20 swap(5 speed swapped)
B13 LE parts car
NX2K RIP (Aug 13 2007) parts car
NX2k soon to be parts car
NX2k my new baby!
NX PART OUT CHECK IT OUT!
http://www.sr20forum.com/mechanical-...-nx-parts.html
We are a community!
jen36 is offline   Reply With Quote
Old 04-12-2008, 02:09 AM   #16 (permalink)
xanomie200sx
SE to SE-R Conversion
xanomie200sx's Avatar
^^^^ Hahahahahahahahaha!!! I like the first video...
Back when I was in high school, I had 2 10" Memphis subs in a ported box, running off 2 Rockford Fosgate P3001 amps. (Same as I have now) Someone broke into my car and took the time to unscrew my subs, take them out of the box, and stole ONE of my amps. They left one amp and the box. It was f*cked up. To this day I think it was somebody I know, even though they haven't resurfaced in another vehicle...
1996 Nissan 200SX SE
PARTS CAR SELLOUT!! 1995 200SX
xanomie200sx is offline   Reply With Quote
