just use a test light..the cig lighter has 2 pcs-an o-lighted ring and the power/grd..
if u dont have a test light or multimeter then u need to invest in some tools..but if ur in a bind for cash then use the voltmeter as a multimeter.
1. remove ur cig lighter from the lower dash unit/and seperate it from the o-ring
2.grd ur multimeter to the blk wire on the power side of the cig lighter or to one of the screws that are under ur shift boot
3.crimp onto the power wire on the cig lighter and touch the ign side of the voltmeter,when u turn the key it should go to 13-14
4.crimp on the o-ring on the cig lighter and thats ur signal for the gauge light
its been a while and the giants just won so i have like 100oz on liq in me and mj just touoched a grapevine so ill x2 in the am
