What up all been a while since i posted on these forums seem to have missed out on a lot of fun. Just wonderin do any of our members have serious sound setups? I have yet to see any in member's rides and such maybe i have missed them. I know most of you guys leane towards the Perf side of life. If any of you audiophiles got anything to show off i would like to see *** we are all runing. I am currently working on a system been runing it quite "ghetto" tough but its still a sound beast as far as loud goes I def wont say im sq king here by far. Post sum pics if yall got anything worth lookin at, and even if you dont..let have a look
P.S lol w.u.t and j.u.s get censored? forcing grammar dam u!
There are some audiophiles here on the forum. I'm in the process of upgrading my system. I actually ran the power wire for my Elemental Designs Nine.2 amp today. What does your system consist of? Got any pics?
I used to have a Power Acoustik FUBAR-10 at 1600 watts, but I came to my senses and now I run Polk components up front and elemental design 6.5" subs in the rear deck of my b13. It has better sound than any car I've been in so far but still enough bass.
Red 92 Sentra SE-R.
-New and improved with a SR20DE+T-
Originally Posted by Shawn B
How come upgrading one part means upgrading other things, which requires further upgrades to the things attached to the original upgrade?
here's mine in one of my Eggs ,, I've recorded an spl level of 152.2db.. all my power is REAL RMS ratings not the big bull crap #'s on the top of some amps, I used Rockford fosgate 0 guage power wire and Tsunami Rca's, juice is supplied from a Red top up front and a 10 farad Tsunami Cap in rear. system is at a 2ohm load...
All Boston Acoustic amps are class AB rated which is cleaner and more accurate with the RMS #'s the any class D amps
Boston Acoustic SL60 sperates
Boston Acoustic GT40-Dual-Mono Power @ 2-ohm (12.6VDC)
2x175W
Boston Acoustic GT28 -Dual-Mono Power @ 2-ohm (12.6VDC)
1x1100W
Boston Acoustic G5 10's in a Tony Boyd enclosure
KDAR JVC3000
For clear, crisp bass without the rattle. Adding Dynamat to the vehicle - especially the trunk -results in higher Sound Pressure Level (SPL).
Dynamat is the easiest-to-apply, thinnest and lightest material for adding sound pressure reinforcement to your car's body. When the panels don't rattle and balloon, you get higher SPL and tighter, louder bass!
and for rear fill I have SL65 coax,, no pic's but will post in a day or two
1991 Nx1600 hardtop 2.0 swap BC Stroker project for 2008
1992 Nx2000 my wake up call
JWTpopcharger,SSAC2.5 header/down pipe VRS CATBACK/Magnaflow,KYB AGX-Hyperco Gen II's,F1 stage3 clutch/flywheel,ES/Prothane motor/tranny mounts, R1 concept front/rear drilled/slotted rotors,AXXIS pads,clear side markers,Maxxim/wheels/205/40/16NittoNeoGens,RedlineMT90,Mobile1,Fstb
I have that same power acoustic sub in my car what's the deal with it. My rockford fosgate was hitting way harder than it till it burned out I replaced it, it burned out again so I sail let me get somethingh that's heavier and an handle high wattage but this thing sounds awful. BTW I'm pushing it with a RF 1200 watt 2 channel amp.
__________________ Once you go turbo you'll never go back!!!
1993 Ruby Red SE-R SR20DE+T RIP junked 3/06
1995 Infiniti G20
1994 Aztec Red SE-R W10DET powered
Originally Posted by capecodbuysell
whats a 2 step and how does it build boost at the line
Originally Posted by GateCrasher_VI
anyone have a spare muffler bearing or two? 'reason to suspect thats where my coffee can sound is coming from
I had mine in a sealed box with some foam and it was more crisp then 90% of the subs I have heard. and it would beat if i turned the bass up, you could really tell it was an old car.
Haha FUBAR....the laughing stock of car audio. Fucked Up Beyond All Recognition
Thats what your Subwoofer will be with some REAL POWER on it....FUBARed.
BTW I have heard Tearoff guys system,it will make your eyes jiggle in their sockets
You get what you pay for,I guess
No eggs in my basket right now
91 Classic Se-r....the resurrection begins
91 300zx NA Slicktop
05 Nismo Frontier 4x4 KC
Sell me your hardtop NX!
ha cool cool. Need to get some pics of my system its a work in progress, need to run 0 gauge power wire runin on 8 still eek. just bought and hooked up a tsunami 5 farad cap, alpine 1000watt rms @2ohm amp- mrp1000 i belive, hooked up to a 15inch Kicker L7 4ohm dvc @2ohms, i got alpine type-r components up front wired 2 a RF amp Looking for a new 4 channel so i can power my rears as well. Sony Xplod Headunit cant remember the model off my head its the 1 that the cd try ejects out meh . when this insane cold stops i'll try 2 get some pics up. I still need 2 reroute all the wires as i currently have the power wires and the signal wires basically on top of each other when i bump hard i pick up interference = terrible. So ye def a work in progress working on making a much nicer install.
tearoff nice install man. dont know if i missed it but what speakers are you runing in the rear if any? How much all that dynamat cost u. i want to do it but its mad expensive.
Lets get more guys in on this! i wanna see some ideas
I just finished Tiffany's (Sumpsychochic's) car this week. Pioneer Premier head unit, 2 old school Xtant amps (1001dx & 604x - the square brass mesh models!!!), an Alumapro C.A.P. 5, a JL 10w7 in a sealed box built into the passenger side of the trunk, MB Quart 6.5" Premium components in the front doors and JBL 6.5" coxaials in the rear deck. Sounds quite nice.
I'll get some pics before I give it back to her this weekend.
Ruby Red 91 NX2000....
White 93 SE-R..........rebuilding
Thanks Bro
I have a pretty penny tied up in the dynamat but would'nt build a system without it,,
Reason: miss spelled a few words LOL
Yes I made it. It needs a little more sanding and primer then it's off to be painted. I still have to glass the bottem and make my amp racks and panel everything else. Just waiting for warmer weather. Here is a picture of my gauge pod I glassed and painted. Sorry if the picture kinda sucks.
I just recently bought a 12 jl audio w7 with a jl 1000/1 amp. I havent hooked it up yet though. But I think it'll pound
Dang skippy boosted that will pound the ground,,, you should put that in a custom slot port enclosure,, I think the Jl performs/sounds better in a ported box
I like the guages,, better than on the piller anyway
